Sparkplugs
Old Aug 2, 2006 | 09:32 PM
Dave_RST's Avatar
Dave_RST
Default Sparkplugs
Just after some advice on which sparkplugs to fit, I've just checked the standard plugs that are in and they are showing signs of overheating, spec is:
1.6CVH EFi Turbo, CVH35 cam, 15 psi.
It looks like I need a hotter grade plug but how do I work out what plug to buy?
Cheers,
Dave
Old Aug 2, 2006 | 09:34 PM
Noisy Boy's Avatar
Noisy Boy
Ive always used ngk R, never had a problem and i have cvh36 kent cam running 12psi
Old Aug 2, 2006 | 09:55 PM
LEE-RS's Avatar
LEE-RS
Custom
motorcraft 071s about £12 from ford
Old Aug 2, 2006 | 10:01 PM
Dave_RST's Avatar
Dave_RST
motorcraft 071s
Are they a plug I'm likely to be able to get from a local motor factors?
Old Aug 2, 2006 | 10:10 PM
Rick's Avatar
Rick
Dave_RST
What signs are they showing exactly?
Old Aug 2, 2006 | 10:39 PM
Dave_RST's Avatar
Dave_RST
The insulator is very white, which I thought was an indicator the plug was overheating?
Old Aug 2, 2006 | 10:42 PM
KSA-Cossie's Avatar
KSA-Cossie
071's or ngk bcr8es m8.
Old Aug 2, 2006 | 10:56 PM
Rick's Avatar
Rick
Dave_RST
You are right
Now you have to find out why it is overheating. The reason for this will 99& be because the car is running lean. New spark plugs won't help this. You need to get the mixture checked out.
Old Aug 2, 2006 | 11:01 PM
Dave_RST's Avatar
Dave_RST
I'm assuming it's because I'm running twice as much boost on standard plugs?
The car has recently been setup by MSD so I would hope the mixture was ok.
Old Aug 2, 2006 | 11:21 PM
Rick's Avatar
Rick
yes, i would think it is. It depends when you are checking them. after a long run on cruise? After a ragging? etc etc.
Old Aug 3, 2006 | 07:15 AM
JesseT's Avatar
JesseT
You need a colder grade plug not hotter.
I usually play with the Motocraft plugs 901 (091) is the hotter option for winter use and the 701 (071) is the colder one for summer/more boost. Both are ridiculously cheap.
Of course it's always good to check the fuelling first.
Old Aug 3, 2006 | 03:04 PM
Dave_RST's Avatar
Dave_RST
Could someone give me the full part code for the Motocraft 071's as I've been to get some today and Ford say that 071 isn't a vaild motocraft part code?
Cheers.
Old Aug 3, 2006 | 05:07 PM
JesseT's Avatar
JesseT
Cheers.
How helpless are they. It's an official ERST plug.
Finis: 1120834 (AGPS071C)
Finis: 5099858 (AGPR 901)
Both 3.55e each when I last got some, so 2£ something.
gazdon
Jan 10, 2010 05:26 PM
YBJ
Nov 22, 2009 06:02 PM
ruthyduthy
Oct 6, 2009 06:14 PM
Escos2483
Ford Escort RS Cosworth
Jan 28, 2009 03:36 PM
Escos2483
Jan 28, 2009 03:32 PM
