Does anyone reckonise these steering column parts.
Old Aug 2, 2006 | 06:43 PM
muppet's Avatar
muppet
Default Does anyone reckonise these steering column parts.
Hi
Do any of you reckonise these steering column parts univaersal joints and bearing. The Bearing no on he seal is SB204-12 LZ. If so what car are they off as I need to get some new ones.
Thanks mupppet.
Old Aug 3, 2006 | 03:19 PM
muppet's Avatar
muppet
BTTT
Come on some of you must know. Please help me.
Thanks Richard.
Old Aug 3, 2006 | 04:17 PM
jon@work's Avatar
jon@work
The bearing doesn't look like a standard car part - go to a bearing supplier for a new one (look in yellow pages for a supplier). If they can't help, it looks very similar to a bearing I bought for a friend from RS Components (including the carrier like yours). Have a look through their catalogues.
The column looks a bit like a modified mk4 escort item - the weld near the joint doesn't look standard, meaning the splined bit is from something else.
Old Aug 3, 2006 | 04:22 PM
muppet's Avatar
muppet
cheers I'll have a look at the RS catologue tomorrow in work and see if it comes up.
Yes the spline part has been welded onto it and isnt a std part. I think the spline bit is from peugeot 205 as thats what my car is but I was pretty sure the rest would have been ford as I have a cosworth steering rack and power steering as its running 4wd sierra cosworth suspension and drivetrain.
Thanks Muppet.
Old Aug 3, 2006 | 04:25 PM
jon@work's Avatar
jon@work
If you look in the current RS Components catalogue 3 page 3-64, the bearing looks like a NSK Flange Unit - bore sizes available are 12, 16, 20, 25, 30mm and 1/2, 3/4, 1 inches, priced at £10.29 to £13.99 (+VAT).
Old Aug 3, 2006 | 09:29 PM
Spiky's Avatar
Spiky
doesn't look familar at all dude
sorry i couldn't help
Old Aug 3, 2006 | 09:36 PM
muppet's Avatar
muppet
cheers for having a look. Apparently theres a driveshaft company in pyle that also overhaul steering UJ's so I am going to go up there tomorrow after work and hope they can overhaul this one for me.
thanks muppet.
Old Aug 3, 2006 | 11:03 PM
tracktoy's Avatar
tracktoy
sorry dude- cant say i recognize it
Old Aug 6, 2006 | 11:10 AM
muppet's Avatar
muppet
Cheers guys.
I have taken it to the place in Pyle now and they can overhaul it. bit pricey but I don't care as it has got to be done and this is probably the easiest fix. I have also ordered a bearing from Wyko in bridgend so hopefully I'll have both on monday and can put it back together.
Thanks muppet.
tankybaby66
Feb 6, 2016 02:24 PM
Fordmad!
Sep 29, 2015 07:03 PM
IainRS1700T
Sep 25, 2015 06:44 AM
dange
Ford Mondeo Including ST
Sep 23, 2015 12:11 PM
