rocker cover gasket.
whats best to use on the rocker cover gasket.
i have both a genuine ford cork and rubber gasket, but which is best to use? i have heard storys on both of them.
cheers
cheers
the cork ones with the little metal pins either side of the bolt holes are best. over tightening becomes less likely to cause leaks, to be honest its best to just trial and error
deathrider666
Sep 28, 2015 06:12 PM
