Ford Focus RS For Sale..... Bargain !!!! £11995.00
Immaculate example of this sort after vehicle, includes all the usual spec that came with the car;
• Sparco leather racing seats
• Sparco metal racing pedals
• Brembo Brakes with uprated discs and pads
• 18" OZ racing alloy wheels
• Fully Documented History with FSH
• 58k miles (Mainly Motorway Commuting)
• December 31 2002 registration, taxed until then, (MOT Nov)
Just had 4 new Tyres - Eagle F1's
Only Mod is a Scorpion Exhaust
Grab an awesome car at a BARGAIN price £11995 ono
Some Focus RS Technical info incase anyone was wondering
FORD FOCUS RS UNIQUE TECHNICAL SPECIFICATIONS
Engine Data
Engine type - 2.0-litre, 16V Duratec RS
Displacement – cc 1,988 Bore, mm 84.8 Stroke, mm 88.0
Fuel type, grade Unleaded petrol
Max power ISO kW/PS 158 / 215 (212 bhp) At engine speed (rev/min) 5,500 Torque ISO Nm 310 (229 lb-ft) At engine speed (rpm) 3,500
Construction
Cylinders - Four in-line, with forged pistons and connecting rods
Cylinder head - Cast aluminium alloy
Cylinder block - Cast iron equipped with improved oil system
Valve gear - DOHC, modified valve seats, sodium-filled exhaust valves
Camshaft - drive Belt
Engine management - Ford EEC-V
Pistons - Forged/oil-cooled by oil-spray nozzles, fed by the main oil gallery
Induction- Garrett stainless steel, water-cooled turbocharger, over 1-bar maximum boost, water-cooled intercooler, new throttle body with improved sealing, redesigned air induction system
Exhaust System - Large bore stainless exhaust system
Injection - Sequential electronic fuel injection (SEFI), High flow rate injectors
Fuel System - 55 litre fuel tank with internal uprated fuel pump, Revised fuel pressure regulator valve
Ignition - Ford electronic distributorless
Emission controls - Closed-loop; 3-way catalytic converter with close-coupled catalyst
Cooling - Increased capacity water pump, high efficiency oil cooler, water-cooled intercooler, uprated engine cooling fans, turbo heat shielding
Transmission
Gearbox - 5-speed, with revised gear ratios, Quaife automatic torque biasing differential, uprated drive shafts. New sports short-throw shifter mechanism.
Clutch - Heavy duty AP Racing
Suspension and Body
Front - Redesigned MacPherson strut suspension with uprated offset coil springs/Sachs racing dampers, 65mm increased track width, revised lower A-arms incorporating a unique all new hydro bush, revised static negative camber, 18 mm anti-roll bar
Rear - Independent, Control Blade multi-link suspension increased in stiffness, Sachs racing monotube dampers with internal rebound spring, uprated springs, increased track width, revised static negative camber, higher load capacity bearings, redesigned spindles, anti roll bar
Brakes
Front - Brembo 4-pot, twin-opposed piston callipers and 325 mm ventilated discs
Rear - Two pot callipers and 280 mm solid discs
Anti-lock braking MK25 Bosch ABS system
Steering
Rack-and-pinion with power assistance, 2.9 turns lock-to-lock
Wheels and tyres - Unique O.Z. alloy 18 x 8inch rims with bespoke Michelin 225/40R/18 Pilot Sport low profile tyres
Body
Computer-optimised, high-efficiency, unitary-welded Steel body incorporating rigid occupant protection cell and front and rear energy-absorbing crumple zones. Side impact protection system. Wider front/rear wings in pressed steel, new reinforced polypropylene moulded front and rear bumpers, side sills and roof spoiler
Interior
Sparco race-style leather/Alcantara trimmed bucket seats in black/blue. Focus rear bench seat trimmed to match. Black/blue leather steering wheel with stitched-in oversteer indicator.
Sparco aluminium handbrake, gear knob, pedals.
Carbon-fibre centre console with start button.
Revised instrument binnacle with new graphics and instrumentation incorporating turbo boost gauge and change-up light.
Unique disc in the centre console with an individual vehicle-build serial number.
Equipment
Power operated windows, power assisted steering, central locking, air conditioning, six-stack dashboard- mounted CD player
Security
Ford Passive Anti-Theft System (PATS) immobiliser, remote central locking with perimeter alarm
Performance and fuel economy (Manufacturer's Estimates)
Performance
Max speed (mph / kph)
144 / 232
0-60 mph acceleration
6.4 secs
0-100 kph acceleration
6.7 secs
0-100mph / 0-160 kph acceleration
15.5 secs
50-100 kph acceleration in 4th gear
8.2 secs
60 - 100 mph acceleration in 4th gear
9.8 secs
Fuel consumption (litres per 100 kilometres / miles per gallon)
Urban
14.2 / 19.9
Extra Urban
7.7 / 36.7
Combined
10.1 / 27.9
Emissions (grams per kilometre)
CO2 – combined mode (g/km) 237
Engine Data
Construction
Transmission
Suspension and Body
Brakes
Steering
Body
Interior
Equipment
Security
Performance
144 / 232
6.4 secs
6.7 secs
15.5 secs
8.2 secs
9.8 secs
Urban
14.2 / 19.9
Extra Urban
7.7 / 36.7
Combined
10.1 / 27.9
Originally Posted by GUZZLER
i've just had Sassy pestering me to look at this post
i've told her if she wants a focus rs then she has to sell the fiesta!!!
You'll have quite a collection then
Originally Posted by seand
was it ever crashed/damaged/sprayed or modified at any time?
This car has come up a couple of weeks to early for me have to sell the lexus first to fund it but have the details and will keep my eye on this if it doesnt sell! it looks like a lovely car
was down SCC the other day... must say it really is in great nick, the last owner must of really looked after it, when i was looking for mine i looked at ALOT of them, most of which had half the miles this one has.. and they wern't in the condition this one is.
Ps good luck with the sale Rob, come on peeps grab a bargin
