motorsport shop
Old Aug 1, 2006 | 05:39 PM
12jedi12's Avatar
12jedi12
Default motorsport shop
I am looking for a motorsport suppliers/shop, like Demon Tweeks in or around Essex. The reason I am not using Demon Tweeks is that I have found that they are rubbish! Does anyone know of any other motorsport suppliers that I could use?
Thanks, Chris
Old Aug 1, 2006 | 07:20 PM
NUTS RuS's Avatar
NUTS RuS
Nobody has the stocks like DT have.
They are one of the biggest.
What you after as there are others who can offer a more personal servce, but only stock certain items.
The trick with Tweeks is to speak to the same person on a regular basis, Most of the sales staff have direct dial numbers allocated to them. Once they get to know you and you them, their over inflated prices tumble dramatically
Old Aug 2, 2006 | 07:47 AM
nthorpey's Avatar
nthorpey
depends on what sort of parts you are after as there are loads of companies out there
Old Aug 2, 2006 | 08:06 AM
S1's Avatar
S1
Gotta agree with Nuts, DT prices may be a bit more than others but I have found their service excellent. You order something and it turns up the next day. If you use them regularly then they look after you, sort you out on postage etc.
Depends if you need something asap or are prepared to wait.
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
