Am i right in saying this is a SUPERCHIP?
Old Aug 16, 2004 | 05:52 PM
Lee Reynolds's Avatar
Lee Reynolds
Default Am i right in saying this is a SUPERCHIP?
And not an Ahmed Bayjoo as i thought it was meant to be?????
Still got the hesitancy prob between 3-4k and its doing my head in now
Old Aug 16, 2004 | 05:53 PM
TIFF's Avatar
TIFF
Chasing Radders
I would say Superchip buy the logo
Ask Rob as he is now a superchips mobile fitter
Old Aug 16, 2004 | 05:54 PM
Physio's Avatar
Physio
Cool! From that angle they look like buildings
Old Aug 16, 2004 | 05:56 PM
TIFF's Avatar
TIFF
Chasing Radders
Lee
was it sold as an Ahmed Chip????????
Lee Reynolds
Yeah i was sure with the logo Tiff! Thing is ive been emailing ahmed as i was told it was an AB chip
Ian M500COS's Avatar
Ian M500COS
I think it's a safe bet to say thats a superchip!
Old Aug 16, 2004 | 05:58 PM
Smit's Avatar
Smit
The 60ft Launch King
where/who u get it off Lee?
cossie1's Avatar
cossie1
tbh I thought superchips had superchips written in full on them
could be a Star Chip but I am no expert
Old Aug 16, 2004 | 06:00 PM
Lee Reynolds
Smit it was in the car when i bought it
Lee Reynolds
oh and i thought rsts ets had soldered in chips? But this is a plug in one
Old Aug 16, 2004 | 06:04 PM
Stu @ M Developments's Avatar
PassionFords Creator
Its a superchip and is very unlikely to be causing any hesitancy.
Old Aug 16, 2004 | 06:05 PM
richm's Avatar
richm
and the socket was probably fitted when the chip was changed
Old Aug 16, 2004 | 06:08 PM
Lee Reynolds
Cheers Rich and Stu. Stu any ideas mate on the problem? PLEASE?
Old Aug 16, 2004 | 07:02 PM
st3v3's Avatar
st3v3
Old Aug 16, 2004 | 07:29 PM
DazC's Avatar
DazC
Lee...
Have you changed the fuel filter?
Also, get a volt meter across the 2 fuel pump terminals and make sure you have a reading as close as possible to what you get at the battery with the car running.
Also get it to an MOT station and check the CO percentage...
Old Aug 16, 2004 | 07:33 PM
Lee Reynolds
Daz, no mate not yet. I am going to but i thought that with the prob being 3-4k all time then it wont be fuelling as that would happen all time????? Going to go and turn boost down quite a bit to see if that works. If so then i want a chip with no boost limit LOL!
Just been MOt'd and co was higher than allowed if that helps?
Old Aug 16, 2004 | 07:43 PM
310bhpctr's Avatar
310bhpctr
fitted at well lane you know
Old Aug 16, 2004 | 07:52 PM
AndyRST's Avatar
AndyRST
Lee save all the hassle and time and possible wasted money, take it to somewhere like MSD, NMS etc get the whole set-up checked and re-setup if needed and see if the problem goes or if one of the excellent places above find the cause
Old Aug 16, 2004 | 07:57 PM
DazC's Avatar
DazC
When the turbo comes on boost it needs all the extra fuel it requires....a lot more than gently driving through it....hence why on boost enrichment is required....if it can't tget the fuel due to a blocked filter then it will hold back.
I have had this a few times on RSTs as well as other cars.
Old Aug 16, 2004 | 10:09 PM
Lee Reynolds
Cheers Daz. I am deffo going to change it this week. Ive not used the car since friday cos we been away for weekend. Deffo will change it, ive wound the actuator back 4 turns, so that should cure it if overboosting, if not then maybe it is fuelling.
Andy. It is going to go to one of those for setup, but i want to get it running ok now and take it when ive fitted a cossie cooler etc
310bhpctr, I have rolling road printouts from well lane so i know cars been there. How do you know?
Old Aug 16, 2004 | 10:24 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
lee they told u nowt else true about car so what u expect??????????????
Old Aug 16, 2004 | 10:31 PM
Lee Reynolds
Gus go and find chunk to play with stop causing shit
Old Aug 16, 2004 | 10:41 PM
Rs Gus's Avatar
Rs Gus
lee go and find a car with the correct shell and then find a working one
Old Aug 16, 2004 | 10:50 PM
Lee Reynolds
I have one. Go and drive wank and roll yours into a field
Old Aug 16, 2004 | 10:52 PM
Rs Gus's Avatar
Rs Gus
i dont think you have go and buy a turd m8 oh u have
Old Aug 16, 2004 | 10:54 PM
SPADGE's Avatar
SPADGE
Do you 2 suffer from pmt? because right now you sound like a right pair of bitches
Old Aug 16, 2004 | 10:56 PM
Rs Gus's Avatar
Rs Gus
Physio's Avatar
Physio
Old Aug 16, 2004 | 11:02 PM
Lee Reynolds
Old Aug 16, 2004 | 11:04 PM
Lee Reynolds
Go and spend your money on a facelift instead of the car you ugly bastard
Old Aug 16, 2004 | 11:09 PM
Rs Gus's Avatar
Rs Gus
your the one with a weasils face not me
Old Aug 16, 2004 | 11:15 PM
Lee Reynolds
I know sloth didnt look like a weasil
MERICK HEAD
Old Aug 16, 2004 | 11:16 PM
Physio's Avatar
Physio
Old Aug 16, 2004 | 11:17 PM
Lee Reynolds
Old Aug 16, 2004 | 11:51 PM
Shings's Avatar
Shings
Lee
Its called Lean stumble and most RST's have it/had it at some point in there life.
Any tuner worth there money can sort it for you- just needs more fuel as it comes on boost- which is what someone above me said- fitting a chip wouldn't have altered this just made it more obvious.
J
Old Aug 17, 2004 | 10:10 AM
Lee Reynolds
Cheers shings
Old Aug 17, 2004 | 10:14 AM
turbinator's Avatar
turbinator
well .. it can still be an Ahmed Bayoo chip ...
when the eprom is programmed you need a sticker of some sort to block the sunlight to the eprom (which could ruin your eprom) ..
So the one making the eprom could have used a different sticker
if you need to know for sure.. you need to get the checksum of the eprom and call mister Bayoo
Old Aug 17, 2004 | 10:19 AM
Its not an Eprom and theres no way Ahmed is going to shove a superchips sticker on one of his chips IMO
Old Aug 17, 2004 | 10:25 AM
Ian2wdsaffcos's Avatar
Ian2wdsaffcos
MERICK HEAD
FPMSL Class
Old Aug 17, 2004 | 11:43 AM
Matt's Avatar
Matt
MERICK HEAD
AFPMSL
calm down angus and leave t'lad alone
he only just getting back into the joys of rs ownership LOL
