vernier pulley
Hello. Can anyone tell me what is the actual difference between a vernier and a standard pulley and if they are worth upgrading. thanks
A Vernier pulley wheel is effectivly an inner and outer wheel, which can be finely rotated and then locked up to give accurate timing .
Standard wheels can only ever get to the nearest tooth.
If you have specced cams that need a fine tune then a vernier will help acheive that result.
If everything is standard then you wont really get a lot of gain from it apart from it being lighter.
To help others here's mine on the 16v engine
The black bit in the centre is effectivly 1 wheel, and the blue bit the second. There are marks and pointers located on both to help you set the degrees.
Rick
Love the motor in the sig fella.
I think I gonna give it a go. Seems a good and most probably a sensible mod for power.
RST Ski
If I cant get it right you can take it off my hands fella
RST Ski
jonfoc
16
Sep 11, 2018 05:35 PM
