ABS removal
Old Jul 29, 2006 | 06:49 PM
RST Ski's Avatar
RST Ski
Default ABS removal
read over this on rsbible
so from what i read is it just a case of removing the modulators and belt, then getting a xr3i master cylinder and new pipes to the front brakes? with compensators
is this it? any hidden catchs?
Old Jul 29, 2006 | 06:56 PM
SafeChav's Avatar
SafeChav
Depends what car it is? An XR3i master cylinder wont be any good on a series 2.
And you will need to get some pipes made up to patch up the piping where the modulators once were.
Old Jul 29, 2006 | 09:27 PM
RST Ski's Avatar
RST Ski
any1 do like a kit for this?
Old Jul 30, 2006 | 05:39 AM
gambit's Avatar
gambit
Default abs removal
its a very simple process and you can keep your master cylinder as i have. Simply strip all the modulators, belts and front brake lines from the vehicle. Then just call a mobile mechanic (or do yourself) to run new copper brake lines from the master cylinder to the t-pieces inside each front arch. The main difference on the abs master cylinder and the non abs one is that the abs one has two extra outlets for the modulators. So with this you simply get a suitable pipe and just run it from the one extra outlet back into the other extra outlet which just makes the brake fluid recirculate in the system Then job done.
There is a diagram on here to show how to route the new brake lines, if you do a search you should find it. Or pm me your email and I will send it to you.
tankybaby66
Feb 6, 2016 02:24 PM
muzzman1
Sep 30, 2015 08:59 PM
