Differences bottom end XR2i 8V <-> FRST
Old Jul 29, 2006 | 09:56 AM
XR2's Avatar
XR2
Default Differences bottom end XR2i 8V <-> FRST
What are the differences between the bottom end of the XR2i 8V and the FRST except from the engine code?
I know from ERST's of changed crankshaft bearings, other oil sump, oil feed for the turbo, other pistons...
But for the FRST?
Old Jul 29, 2006 | 10:26 AM
jrs's Avatar
jrs
Fiesta rs turbo and the escort rs turbo are the same bottom end's just the frst has a crank sensor fitted. The only thing the xr2i has that is the same as the frst is the crank sensor
Old Jul 29, 2006 | 07:14 PM
XR2's Avatar
XR2
But what about the oil feed for the turbo XR2i - FRST? And the sump? Main bearings?
Old Jul 29, 2006 | 09:20 PM
jrs's Avatar
jrs
All diffarent the xr2i is not low comp sump is the same and there's no oil cooler
Old Jul 29, 2006 | 11:12 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
cranks are different (same throw, but different profile around the journel) as are pistons, oil feed can be fitted or removed from any cvh
block has oil return in a frst xr2i doesnt
beleve shells are different like the rst
some other shite too no doubt
mike elsome
Sep 14, 2015 04:08 PM
Tank Mike
Sep 10, 2015 07:56 AM
rsstav
Sep 7, 2015 04:43 AM
Ben26
Sep 3, 2015 07:55 PM
