What else to change in the g'box area ?
Going to be ordering a CTS Stage 2+ g'box soon, but wondering whilst the current box will be off, what else can i squeeze in there ?
I want to get a new clutch, and was told to get an AP organic clutch (as the car is used every day), but I just spoke to a mate who had a AP in his Scoob which went very bad ... aparently its becoming very common for this fault occuring.
Anything else in that department to change ?
if you get an ap organic one make sure it the high torque version (organic), the clutch code has /35 in it. You will not be disapointed, believe me i have the same box as you are getting and i run that clutch. Make sure you get the flywheel skimmed and a new crankshaft oil seal for behind the flywheel (the big one).
of course it will mate
its better than o.k its perfectr
because its an organic one it is very light and user friendly. The reason i say get the high torque versaion is so that you dont have any trouble with a slipping clutch
23
Sep 12, 2015 12:56 PM
blakey100
Aug 4, 2015 08:17 PM
