T 34/T35?
Same turbo 2 names....LOL
t35 is usually referred to as this from a 4x4 t3 modded to a t34 spec. as in a T34 with a .48 rear housing....
But essentially its the same turbo.
Just specify the .48 / .55 / .63
55 is the best one IMHO
THE TWO TURBO's A VERY DIFFERENT!
One is more suited for a YB setup and the other anything smaller.
The T34 blades are very different to T35 Blades i.e the air flow charateristics.
I use the T35 on a FWD car upto 300bhp over that a T34 would be better.
T34 has more lag than a T35 down to the shape of the Compressor blades and design housing.
Jano - how do you overcome the fact the T35 is designed for diesel application i.e not for the heat of a petrol car?
...it's a bit like trigger's broom
So....you dont have to overcome anything! Apart from opening your eyes to other ways John.....
my eyes are always open to new things. Mine was a serious question. I thought the wheel was made of a different material, always willing to be corrected.
So a Standard T35 will just bolt on without any internal mods? Apart from obviously it being the wrong bolt pattern (as a T34 is for RST)
How does it flow compared with a T34?
Originally Posted by jano oddkid
No the compressor wheels are made from the same material.
how about the turbine wheels? the compressor wheels don't exactly have the hardest job, and there doesn't need to be a difference there for petrol or diesel.
I have graphs for Three cars that run these Turbo's we are talking about,
One is on a FRST 1900cvh 803's T34. He has 296bhp & 295lbft
He would make more power with a smaller Turbo and zorst Housing
One is a ERST 1600cvh T35-48a/r 803'2 & leaking valve seats
275bhp 265lbft
One is a FRST 1800zvh 803's T35-63a/r = 260bhp & 245lbft
He would also make more power with a smaller zorst housing
Some of the graphs can be found here
http://members.lycos.co.uk/oddkidd/forum
275bhp 265lbftOne is a FRST 1800zvh 803's T35-63a/r = 260bhp & 245lbft
But yes you are correct in saying that these componets (Shaft) are different and will change depending on the fitment, temps, and size etc etc...
So what about the turbine wheel - is this changed?
you use the front end of the Turbo to rebuild it into a hybrid (if wanted) using :-
Maram (if wanted) Cut back (If wanted) L/H, Shaft with Step Adjusting oil seal
360 thrust bearing, oil thrower and seal.
New back plate and gasket/seal (If uses a seal as some dont)
New Compressor blades
New Compressor Housing
New journal housing cut for 360 (if wanted)
New Journal bearings (uprated if wanted)
New shrowd
New Criclips
New Bolts and Clamps
New oil return gasket
Left hand lock nut
you have a Shaft which has a friction welded Turbine wheel attached to it (STD) which is the exhaust driven blades and the compressor blades which sit inside the compressor housing and is not attached to the shaft but is clamped down with a nut on to the shaft sometime have a lefthand thread on them to stop them undoing.
So yes a Shaft and Exhaust Turbine are the same thing really as they dont come apart unless you overspeed them
Originally Posted by Jano_OddKidd
Of course in a T35
New shrowd
New Criclips
Left hand lock nut
New shrowd
New Criclips
Left hand lock nut
EsCos (large turbo model) std turbo was a T3/04B
EDITED:
not for Damo - your post wasn't there when I replied
Originally Posted by Damo V
So how would you tell a T3/04 (ECos) and a T35 apart externally????????
I was also of the impresion they were one of the same
They are not the same,
If you had both compressor blades on a table (Side view) the T34 blades are wide apart and not very high. The T35 blades are compact together These blades look more triangulated <sp (From the side) and are taller than the T34 type.
I will take a pic for you tomorrow
Of course in a T35
New shrowd
New Criclips
Left hand lock nut
New shrowd
New Criclips
Left hand lock nut
cheers
