are siemens beige injectors the same as bosch?
errr
no
yes they may look the same, but then theres the inpedance, flow rate to consider.
unless of course if you wanted to know if they'd fit a car that has previously had bosch injectors in, then as long as the dimensions are the same, then yes, they'd fit
no
mk3ste
Oct 17, 2021 10:09 AM
timsrs
22
Sep 24, 2015 08:14 PM
