IS R.A.C MAN TALKING SHIT???? Yes it turns out he was.
Right,was driving my car today and the big think amp lead was connected to the battery but not the amp.Therefore had a live wire in the car.This then earthed and the car cutout ,no ignition.Phoned R.A.C and he came out disconnected the lead from the battery,but it still wouldn,t start.He said it has fucked up my E.C.U....I thought he was talking bollox,but it still won,t start
fuck knows mate,,,,,,,,,,,doubt he can tell either unless he takes the ecu apart and tests it
could have burnt out the loom,,,,,,,,, fired the starter,,,,,,,,,, hel theres loads of things it could be
if its a MFI erst you got then its more likley a breather hosue is undone
infact i think the ecu has a 1 way resistor in it to prevent negative frying , not to mention that live against live wont go untill the igniton is turned off and the switched live goes negative
He is talking sh*t.
More likely to have blown a fuse as said above or another earth wire
elsewhere on the car.
As an aside, I dont think most patrol men are "clued up".
I used to work for a company that supplied RAC with diagnostics testers.
They had a RED and BLACK wires for connection to the vehicle battery
and labels on the coloured wires saying positive/negative.,
Nearly had 50% of them returned for damage caused by connecting them
up backwards.
Thick cnuts
up backwards.
Thick cnuts
Originally Posted by Damo V
Check all your fuses and the fused wire at battery, tbh you are lucky you still have a car..
As Damo say's I have had the misfortune of a Batt moving under the bonnet of an old S1 I had burnt out every fecking earth but E.C.U. survived
And to be honest I contract for the RAC and if they aint got a clue which most have not its always the E.C.U. Thats at fault prob popped fuse or burnt out earth !.
Regards Doug .
Originally Posted by SECS
He is talking sh*t.
up backwards.
Thick cnuts
up backwards.
Thick cnuts
R.A.C. = Ring A CUNT
Regards Doug .
He is talking sh*t.
up backwards.
Thick cnuts
up backwards.
Thick cnuts
Originally Posted by James
on a side note i have fried a ecu though simply connecting jumpleads without a surge protector, so don't go thinking ecu's are indestructable!
you never shorted the live to the neg
He is talking sh*t.
up backwards.
Thick cnuts
up backwards.
Thick cnuts
My old Orion caught Fire behind the dash and i got it put out with a bottol of coke
Got it recovered home and was to;d it needed a new Loom and yes it did as half the wire behind the dash had melted togher ,
My E/W Ect would go up as they had no power it turned out the wire that goes from the Fuse box to the Battery had melted and snapped off @ the battery end it goes from Thick to a smaller wire
So if you got nothing then look there m8
why didnt you fit a brdge rectifyer on the supply circuit then
Ok here goes....
The power input positive was protected by a series diode to prevent
power reverse polairty which in its own right works fine.
A bridge rectifier could NOT be used as this would raise the ground voltage
level with respect to the vehicle earth about 0.5 volts higher and this
would affect comms signal quality and switching reference levels up.
The problem comes when the lead connecting the tester to the car
diagnostic socket has its own ground in the lead.
So, when the tester is plugged in to the car its own earth is correct.
Then when you connect the GROUND battery lead accidently to positive,
this created a short circuit across the battery - BANG.
The unit was protected with a fusable resistor in the comms lead ground
connection which is designed to blow in such circumstances to protect
from it from fire.
Hope that explains it.
He is talking sh*t.
up backwards.
Thick cnuts
up backwards.
Thick cnuts
simon i ment it as in them sending back stuff for warranty when they fucked em up by being dick heads rather than using it as a cheap dig against you
erning out of someone stupidity who should know better aint such a bad thing imo, just business
if i was gonna make sly digs at you i owuldnt have bought a S8 ecu would i,,,,,,,, that would be more idiotic than the colour blind rac men
not everyone is a enemy on here
SECS
i was teasing simon
i was teasing simon
Gareth,
On some of the communications data links, even a 0.2 volt difference
did cause issues on the design.
There are ways around it like you have mentioned but there were other
issues why this had to be a direct link.
I did suggest a fitting a 2 pole relay which only turns on when the power
was correct polarity but this was rejected for cost and space reasons.
cool simon
been ages since ive done some tidy electronic design,,,, i have promised myself to get back into it one day and learn more about digital electronics and not just the passive shite
Just pipped me to the post Simon
or Rent A Clown
Regards Doug .[/quote]
Bugger! I just paid 80quid to be a member!
lol TBH i would only want them to sling it on a truck though
(not that i actually own a car at the mo
or Rent A Clown
Regards Doug .
Regards Doug .
)[/quote]To be fair im a member also
But only as it was the cheapest quoted recovery for any long distance
Local is sorted as i work for a Recovery firm but some of the jobs you get Via the RAC is funny as Feck
Regards Doug .
GARETH T,
I hate analog/passive electronics - It can be so random sometimes
Its all going to be truly digital one day.
Look at most comercial electronics now. More silicon and less carbon !
You can already get single chip PC's
"Ring A Cnut " PMSL @ Doug
GARETH T,
Regardless of what some idiots on here say I still stand by you and think you a very knoledgable person and one that know's his electronics shit
Hat off to ya mate
Regards Doug .
GARETH T,
Hat off to ya mate
And i will second that
Hat off to ya mate
Doug, Costina,
Thanks for that
I am sticking to designing only from now on and letting others do the hard
work.
I finish my current full time employment end of this month as I was
on long term contact work but now have a new venture !
(its a secret for now - so that others dont ruin it before its had a chance)
Thanks for that
work.
Went over the car today after work,couldn,t be bothered last night as the R.A.C man had prepared me for the worst.Anyway turns out a use had popped in of all places(THE FUSE BOX).Thank you R.A.C.
Ok here goes....
from it from fire.
from it from fire.
But fuck me fella - you're a bit fooking intelligent!!!!!
Not that I understood any of that up there, but shit, you seem to know your stuff pal
rsguy
44
Sep 29, 2015 03:29 PM
