differences between 1.4 efi head and 1.6 efi head
Old Jul 22, 2006 | 06:35 PM
steven botes's Avatar
steven botes
Default differences between 1.4 efi head and 1.6 efi head
are these two heads different - the vlaves look smaller but have been told the two heads are the same
reason im asking is because unleaded fuel will be limited shortly in RSA
and ive seen a efi head with 1.4 stamped on the side that has valve inserts that i may want to use
Old Jul 22, 2006 | 07:48 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
with carb heads the 1.4 ports are loads smaller than the 1.6 i'd assumne it was the same with efi heads
what fuel are you intending to use if you are lacking in unleaded??
Old Jul 22, 2006 | 07:52 PM
SafeChav's Avatar
SafeChav
UNLEADED fuel will be unavailable???
What are the cars going to run on then?
Old Jul 23, 2006 | 05:31 PM
NEWTON's Avatar
NEWTON
i think the combustion chambers are different
Old Jul 23, 2006 | 07:25 PM
steven botes
scrap that , i meant leaded!
Old Jul 23, 2006 | 07:52 PM
1.9 xr2 on 40's
st170 breaking
i'd hazard a guess and say any efi will be ready to take unleaded just as they are over here
Old Jul 23, 2006 | 08:23 PM
SafeChav's Avatar
SafeChav
Even the early heads will run comfortably on unleaded. My run about car is a 1985 Orion Ghia I with an 81 cast head (original factory head) and has been happily running on unleaded for years.
Have a look on www.pumaracing.co.uk/cvh.htm there is a lot of good information
Old Jul 23, 2006 | 08:42 PM
steven botes
cheers mate
puma racing says no problem
Old Jul 24, 2006 | 09:12 AM
SafeChav's Avatar
SafeChav
Exactly why i showed you the link
gcfcos
88
Sep 15, 2015 03:48 PM
RSmark84
Sep 13, 2015 01:29 PM
kevin36
Sep 8, 2015 12:23 PM
bigryrs
Sep 7, 2015 06:45 PM
hopper350
Sep 4, 2015 12:53 AM
