would this clutch be any good for my RS turbo?
Old Jul 21, 2006 | 09:48 AM
twinkle_2k86's Avatar
twinkle_2k86
Default would this clutch be any good for my RS turbo?
found this on fleabay, but i have checked on microcat, and the kit part number quoted on the add is not for a RS turbo, altho it says its the same clutch plate.
so would the clutch spring plate not be up to the job?? or would you think it was ok??
http://cgi.ebay.co.uk/NEW-FORD-XR2-X...QQcmdZViewItem
cheers
Old Jul 21, 2006 | 10:06 AM
DanRSturbo's Avatar
DanRSturbo
Double check the part number with your local ford dealer
Old Jul 21, 2006 | 11:59 AM
SafeChav's Avatar
SafeChav
That clutch is 220mm so it is suitable for a Series 2
Old Jul 21, 2006 | 03:16 PM
twinkle_2k86
this is the number the guy has quoted me on the clutch plate
clutch plate is a motorcraft 90ab-7550-cb
so can anyone check for me please to see what this is, as im at work at the mo, s cant get access to micocat
cheers
Old Jul 21, 2006 | 03:23 PM
SafeChav's Avatar
SafeChav
I cant find that part number on there for shit
Infact, i cant even see a clutch bigger than 190mm.
That clutch will defo fit an S2 if its 220mm
Old Jul 21, 2006 | 03:40 PM
twinkle_2k86
ok cheers and i didn`t think it was a ford number TBH anyway, just didn`t look right.
cheers again tho mate
Old Jul 21, 2006 | 03:47 PM
SafeChav's Avatar
SafeChav
Theres a letter missing from the middle bit from what i can see.
As long as its 220mm it will work Same as the XR3i's and XR2i's aswell i believe
markk
Dec 2, 2021 06:59 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
neil18
Mar 14, 2016 01:08 PM
3i Jim
Nov 20, 2015 05:12 AM
druidgetafix
Aug 15, 2015 10:22 AM
