amal disconnected
Jul 20, 2006 | 06:11 PM
amal disconnected
would the car be really flat with the amal plug off?
Jul 20, 2006 | 06:13 PM
Shouldn't be if your actuator/boost control method, is set up correctly.
Steve
Jul 20, 2006 | 06:14 PM
mines standard, so it will boost even tho the plugs off?
Jul 20, 2006 | 06:21 PM
Sorry mate, my bad. I thought you meant plumbed out.
Disconnect the plug it will be on low boost yes!
Apologies.
Steve
Jul 20, 2006 | 06:22 PM
i see, cheers
Jul 20, 2006 | 07:17 PM
Right now if i plumb up a bleed valve, when the valve is fully wound in will i be on standard boost? (or wotever the actautor is set to)
Jul 20, 2006 | 07:18 PM
yes.
read the thread further down aboul amal valve wiring.
Jul 23, 2006 | 09:31 AM
i thought if the wiring to amal valve was disconnected it would only run half boost!
as the ecu pulses it to open on full boost!
steve.rst
Mar 15, 2016 08:01 AM
rs_jim
Sep 19, 2015 08:41 PM
hopper350
Sep 4, 2015 12:53 AM
muffster
Aug 11, 2015 05:39 PM
jdsjojo
Aug 1, 2015 08:50 PM
