zvh
Old Jul 18, 2006 | 09:46 PM
mk3cable's Avatar
mk3cable
Default zvh
ive built a non turbo 1.8 zvh will i need to skim the head to build the compression up any help welcome as its going the the enginerers tomorrow
Old Jul 19, 2006 | 09:14 AM
ballin's Avatar
ballin
why have you built a non-turbo zvh?
if the bottom end is a std N/A zetec then no you wont need to skim the head as all you are doing essentially is taking off the superior zetec head and dumping a 8v cvh in its place.
very pointless, but very simple
Old Jul 19, 2006 | 09:15 AM
ballin's Avatar
ballin
which HG are you using? you may need to get the head welded or the block will need some work.
be so much cheaper and easier to drop a zetec head on can i ask why you are doing it?
Old Jul 19, 2006 | 09:35 AM
MAD EVO 4's Avatar
MAD EVO 4
This does seem strange if your not going to turbo the engine
Old Jul 19, 2006 | 09:57 AM
Porkie's Avatar
Porkie
EXACTLY!
Old Jul 19, 2006 | 10:00 AM
reality's Avatar
reality
People do strange things......
Old Jul 19, 2006 | 09:02 PM
mk3cable's Avatar
mk3cable
the reason i have done this is to have more reliability as my car is a 23 year old xr3 and cvh engines are dated and usualy high milage, the 18 bottom end came out of a 66k escort which a mate owned but didnt put any anti freeze in and cracked the head, in my line of work this conversion is quite easy as i have got all the tools. so why not! IS THIS STIIL STRANGE!
Old Jul 19, 2006 | 09:04 PM
MAD EVO 4's Avatar
MAD EVO 4
ivge got a zetec head you could of had and save fart arsing about fitting a cvh head
Old Jul 19, 2006 | 09:08 PM
mk3cable's Avatar
mk3cable
to late
Old Jul 19, 2006 | 09:09 PM
Rab's Avatar
Rab
Fucking superstar........
I still can't understand why people mate the shit bit of a zetec with the shit bit of a cvh
Old Jul 19, 2006 | 09:17 PM
mk3cable's Avatar
mk3cable
the shit 66k zetec bottom end is better than a shiter 100+k cvh botom end and the shit cvh head is better than a shitter cracked zetec head! is that easier to understand
Old Jul 19, 2006 | 09:49 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
ignore what people think, you do what you want! i built one with spare bits and it rocked! the answer to your question is yes, you will need to skim the head... quite alot iirc, something like 1.5 or 2mm on a 2.0 bottom end to get a descent CR (this is only if it uses the hemi head, not the lean burn!).
good luck with it
Old Jul 19, 2006 | 09:55 PM
mk3cable's Avatar
mk3cable
whats a hemi head and i have sent it off to be skimed 2 mm after speaking with brom from zoo motorsport
Old Jul 19, 2006 | 09:59 PM
Turbo Zetec
Engine Machinist
a hemi head has round combustion chambers, a lean burn has heart shaped ones
Old Jul 19, 2006 | 10:03 PM
mk3cable's Avatar
mk3cable
it is the rounded 1 nice 1 for the help
Old Jul 21, 2006 | 11:56 PM
TONY C's Avatar
TONY C
Old Jul 21, 2006 | 11:59 PM
TONY C's Avatar
TONY C
Old Jul 22, 2006 | 12:01 AM
TONY C's Avatar
TONY C
The head needs skimming.
Old Jul 22, 2006 | 06:27 AM
ballin's Avatar
ballin
even more reason not too then! but fair enough thought they were okay unskimmed!
Old Jul 22, 2006 | 08:15 PM
rsturbowhite's Avatar
rsturbowhite
mk1turboestate
Dec 2, 2015 08:31 PM
Chas
Oct 5, 2015 07:13 PM
davidfordrs
Sep 23, 2015 02:26 PM
davidfordrs
Sep 21, 2015 04:23 AM
Del gsxr
Sep 19, 2015 05:53 PM
