Try and diagnose this if you can!
Old Jul 18, 2006 | 12:16 PM
Ade's Avatar
Ade
Fast Ford snapper
Default Try and diagnose this if you can!
Trying to get my S1 engined Escort up and running but I can't get it to stay running!
What happens.......
Starts from cold, but wont't idle, lots of revving needed to keep it running otherwise it cuts out.
Try and take it around the block, it cuts out.
This time it won't start..... leave it for a few minutes and it starts and for only a few seconds before cutting out....
(much more badly behaved when warmed up)
Also bear in mind it's all home built and wired and I haven't been able to get it reliably running yet.
Give me your best shot!
Old Jul 18, 2006 | 12:28 PM
TURBO BOI's Avatar
TURBO BOI
poss air leak or fuel starvations from ur description
Old Jul 18, 2006 | 03:17 PM
SafeChav's Avatar
SafeChav
Could be near on anything.
Without any disrespect how confident are you that all the wiring work is spot on?
Old Jul 18, 2006 | 05:32 PM
Ade's Avatar
Ade
Fast Ford snapper
I'm not confident about any of it!
Initially when it first failed I took it out a drive and the turbo spooled up real nice, but then it backfired big time......... and would only run for a couple of seconds at a time afterwards......
Feel free to throw some ideas my way though as I'm needing some!
Anything to get the ball rolling cos I'm stumped!
Old Jul 18, 2006 | 05:34 PM
SafeChav's Avatar
SafeChav
Ahhhhh..........well, so you've had it running nicely, even if it wasnt for very long? And as soon as u thraped it its been playin up?
Old Jul 18, 2006 | 06:20 PM
Ade's Avatar
Ade
Fast Ford snapper
Well, the time when it ran reasonably well and then backfired to a halt was a year ago!
I'm just getting back to work on it now....with no luck!
Old Jul 29, 2006 | 11:44 AM
neds2rst's Avatar
neds2rst
Default try this think a had same oproblem
the fuel pump was not running eight bar of fuel presure like it meant to which mens car was only running on cold start valve and wasv not opening injectors every tim it would start idle but not really want to rev or drive a put new one in there was a reall heavy cquealing from metering head at first and it fired up and drove no prbs
Old Jul 29, 2006 | 11:57 AM
Ade's Avatar
Ade
Fast Ford snapper
The car's got a new fuel pump fitted, but there's always the chance that it's not getting enough power?
Think I may try 'hot wiring' it....
Old Jul 29, 2006 | 12:46 PM
SafeChav's Avatar
SafeChav
Do a voltage test across the pump terminals
Old Jul 30, 2006 | 12:34 PM
Ade's Avatar
Ade
Fast Ford snapper
Possibly a more sensible idea!
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
van_dogg_pavvy
Mar 3, 2016 09:30 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
fatboy billy
Aug 3, 2015 08:34 AM
