2wd engine
Old Jul 17, 2006 | 09:57 AM
turbodan's Avatar
turbodan
Default 2wd engine
As above the bottom end was rebuilt 1500 miles ago. I rebuilt it because i thought at first the head gasket had gone because i was getting a small amount of oil in my water when i put it back together the oil was still getting in so i took the head off again and had it pressure tested again. put the head back on last week and its worse now than ever.Ive now had enough and bought a new engine complete so im selling this to anyone who might want to sort it out or break it for bits.
205 block on standard bore
4x4 pistons with valve cutouts
crank on standard grind with new shells
brand new high pressure oil pump SOLD
4x4 oil pump with pick up pipe and spray bar
set of standard 2wd pistons
head which i still suspect to be the fault standard with new valve stem seals and lifters
engine runs perfect
offers
cheers
Old Jul 17, 2006 | 10:00 AM
Jay,'s Avatar
Jay,
Sponsor
mate split it down ull get more in the end for crank ect
Old Jul 17, 2006 | 10:04 AM
turbodan's Avatar
turbodan
if anyone wants any specific parts and makes me a serious offer i will
Old Jul 19, 2006 | 12:13 PM
St3V3_C's Avatar
St3V3_C
Dan, remind me later mate, and I'll put up those pics of the bottom end after the build.
Old Jul 20, 2006 | 07:13 AM
turbodan's Avatar
turbodan
ok cheers steve
Old Jul 21, 2006 | 04:40 PM
St3V3_C's Avatar
St3V3_C
Ok, here's the pics I took after it came back from the build...
Old Jul 25, 2006 | 07:30 AM
turbodan's Avatar
turbodan
bttt
Oct 9, 2015 07:38 PM
FlashRS
13
Aug 31, 2015 06:02 PM
lockie
Jul 31, 2015 10:03 PM
Old ford
Jul 31, 2015 06:50 AM
