put amal back on and..
Old Jul 16, 2006 | 04:15 PM
morto's Avatar
morto
Default put amal back on and..
hi all just put ma amal back on to see if it helps with my lag, how many turns down on the actuater do you think? i thought about 6.. its a -34 btw
thanks
andy
Old Jul 16, 2006 | 04:17 PM
Graceland's Avatar
Graceland
Team HOTHOT!
That means absolutely nothing. Considering how many variables there are.
Size of jet in amal valve
boost you are running
spec of turbocharger
wear factor on the actuator spring/diaphram
engine type/displacement
exhaust and inlet manifolds etc etc etc
Old Jul 16, 2006 | 04:18 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
eh?
how do you think this will change your lag?
Old Jul 16, 2006 | 04:21 PM
morto's Avatar
morto
Originally Posted by Lambchop
eh?
cus the amal works abit like a electronic bleed, the same as takin the amal off and putin a brass bleed in, you bleed abit of boost off to get a better power curve, or so i was told by some one on here
andy
kyle_st200
Ford Focus Diesel
Aug 21, 2015 09:28 PM
john_3.0s
Aug 16, 2015 06:40 PM
Michael Wisbey
Aug 14, 2015 11:57 PM
muffster
Aug 11, 2015 05:39 PM
jdsjojo
Aug 1, 2015 08:50 PM
