how big??
Old Dec 19, 2003 | 04:22 PM
Default how big??
i have a Fiesta RS droped wiv spax shocks and springs 30mm all roun wats the biggest wheels i can fit with no mods?? ive been told 15's? then told 17's? then told 16's? thanks for helping.
Old Dec 19, 2003 | 04:34 PM
15s with 195/45-15 tyres are perfect. 195/50-15 tyres normally rub a bit.
16s go on some fiesta's ok, but some rub the spring cups.
17s & you normally need to use spacers & roll or trim the arches.
Old Dec 19, 2003 | 04:36 PM
cheers mate
Old Dec 19, 2003 | 08:35 PM
ive been told with 15's i will need spacer's? is this rite?
Old Dec 23, 2003 | 09:03 PM
Someone HELP pls.
Old Dec 29, 2003 | 11:53 AM
My XR2i is lowered 35mm with 15" wheels with 195/45 rubber with no rubbing even when loaded up. I didn't need spacers either.
Old Dec 30, 2003 | 05:15 PM
lovely jubly cheers mate.
Old Jan 3, 2004 | 05:14 PM
chumkila's Avatar
chumkila
its abit hit and miss, some will rub even with 15's and others won't.
Old Jan 3, 2004 | 11:57 PM
what size would people recomend? ive been told to stick with standard size and just change the wheels for a better design off alloy im thinking of getting a set of TSW Blasts and they only come in 13 and 14 inch any way. any help would be good
Old Jan 4, 2004 | 01:14 PM
you should be able to get 15s on with no probs my fiesta is on a 35ml offset anything else cause problems i have got no archs on my car and these wheels are of a peugot 306 with 1 inch and half spacers its lowered 40ml on koni adjustables the bigger the wheel the smaller the offset needs to be hope that helps
Old Jan 14, 2004 | 03:39 PM
FEZZY*ROB*'s Avatar
FEZZY*ROB*
15s fit with no ach mods with avo gas ajustables, 16'' fit with slite front arch mods but no rear mods that using a 7'' wheel
Indyrs
Dec 4, 2022 12:39 PM
Nov 1, 2015 06:53 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Nick 172 Sport
Sep 28, 2015 07:21 PM
SMILER258
Sep 28, 2015 09:04 AM
