help needed with my saff cosworth.
Old Jul 13, 2006 | 09:19 PM
rs graham's Avatar
rs graham
From: In the pub cheering on Ricky hatton and Joe calzaghe
Default help needed with my saff cosworth.
iv just put a second hand gearbox from pete in my saff,after my one started to wine big time!
anyway after fitting the box,i now have a vibration as i speed up! it fills like the prop shaft is out of balance...iv fitted a new cross member bush,cos mine looked fu*ked but its still doing it!
please help
Old Jul 13, 2006 | 11:07 PM
gambit's Avatar
gambit
Default VIBRATION
i aint sure but maybe if you fitted an uprated bush that would be the cause of the vibration, but aint sure. Uprated bushes tend to cause vibration i have found as there is very little play in them.
Old Jul 14, 2006 | 05:47 AM
rs graham's Avatar
rs graham
no mate,it came from ford so just a norm one!
Old Jul 15, 2006 | 12:51 PM
rs graham's Avatar
rs graham
anyone
Old Jul 16, 2006 | 10:14 AM
cossiestu's Avatar
cossiestu
I had an identical thing, altho, it came out of the blue, (hadnt been working on the car or anything) had the prop balanced, then realised an engine mount had gone.
Might be worth a check, incase you knackered it, jiggling the gearbox back in......?
Old Jul 16, 2006 | 10:59 AM
davecosworth's Avatar
davecosworth
IM BACK
have you replaced the bush and bearing in the middle of the prop these tend to go i had to doone on my saff
Old Jul 16, 2006 | 01:06 PM
silky16v's Avatar
silky16v
Get on That!
Clutch what condition is it in if it knacked or fallen 2bits it'll cause an vibration happened on me when half the clutch fell 2 bits
Old Jul 19, 2006 | 09:16 PM
Cosworth-PT's Avatar
Cosworth-PT
I had just the same problem. done a lot of things but it was solved by installing a new clutch kit (release bearing + clutch + cover). in mine vibration was so strong that the plastic central console broke.
mk22door
49
Mar 26, 2022 07:15 AM
mrmann
Aug 20, 2015 11:24 PM
James Porter
Aug 14, 2015 12:43 PM
col93saphcos
Aug 7, 2015 03:21 PM
ricky
Jul 31, 2015 10:30 PM
