Scort hunting
Old Jul 13, 2006 | 12:35 PM
hodgie's Avatar
hodgie
Default Scort hunting
As title 97 1.6 si scort hunts (sometimes) also using shit loads of juice any one got any ideas plz?
Old Jul 13, 2006 | 12:39 PM
costina's Avatar
costina
Live long and prosper!!
Check lambda sensor the wires to it can and often break this will cause excessive fuel and poor running!!!!!!!!!
Old Jul 13, 2006 | 12:52 PM
hodgie's Avatar
hodgie
Nope not that wires from the sensor are fine..
Old Jul 13, 2006 | 01:26 PM
costina's Avatar
costina
Are u sure the sensor has not packed up ?and are u getting a live feed to it? is it ok when cold?
Old Jul 13, 2006 | 07:17 PM
davecosworth's Avatar
davecosworth
IM BACK
there is a smale rubber hose on the crank case breather system under the coil pack these tend to split with age and make the car hunt and use alot of fuel as it is also part of the emistions control system ford do still sell them as i brought two today the are about 2 inchs long and have a 90 degree bend on the end if you need the part number i will dig it out for you
Old Jul 14, 2006 | 07:48 PM
hodgie's Avatar
hodgie
will go take a look now..
Old Jul 14, 2006 | 07:55 PM
hodgie's Avatar
hodgie
Can see two pipes one i believe is aircon the other fucks off towards the bulk head no 90 degree bend in it and it seems fine both of these are under coil pack , any idea?
Old Jul 14, 2006 | 08:40 PM
costina's Avatar
costina
another guess is if it has a maf sensor then take pipe of and blow out ,this can give a false reading if it has moisture in it and make if overfuel.
The only other thing is to get a mobile tuning man
Old Jul 14, 2006 | 09:09 PM
escort mk6's Avatar
escort mk6
have you tried cleaning the idle control valve?
Old Jul 14, 2006 | 09:16 PM
hodgie's Avatar
hodgie
where's that on the escort?
i know where it is on the cossie.
Old Jul 14, 2006 | 09:18 PM
hodgie's Avatar
hodgie
a mate just mentioned the MAF will have a look in the morning..
Old Jul 15, 2006 | 01:15 AM
davecosworth
IM BACK
ok mate there is a crank case brather under the exhaust mainifold on the front of the engine on the gear box side of this unti there is a tubber pipe that jions into a metal pipe that is held under the coil pack by one of the gearbox bolts it runs up along side the engine the joins in to the ruber hose that i was saying about b4 and this joins onto the inlet mainifold on the bottom corner trust me it is there
Old Jul 15, 2006 | 08:11 AM
silencer's Avatar
silencer
ate ya rev's playin up on idle aswell coz it prob b the idle control valve got that prob on mine but i got the 1.8 i think the icv is under the throttle body and a bastard to get at..
23
Sep 12, 2015 12:56 PM
muffster
13
Sep 3, 2015 09:40 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
