Hi
Just remembered i had signed up here lol.
Im looking for a 1st car and in my search i have found this Ford Escort not sure what Mk
>>ClicK<<
So i have a few questions: -
What Mk is it?
What problems(if any) should i be looking for?
Im not sure on any questions
so if any of you want to add anything then that would be great
Thanks.
>>ClicK<<
What Mk is it?
Thanks.
It's a Mk5
Look for rust, EVERYWHERE
especially around the rear arches although they're not as important as the sills....
BUT it says it has 12 months MOT and for Ł425 that's a years worth of cheap motoring
Engines on those are fairly reliable, also look out for bottom arms on the suspension, listen to it as you pull away in a straight line or steering slightly, if there's a clunk they may need replacing.
Not tremendously expensive to fix though so not the end of the world
especially around the rear arches although they're not as important as the sills....BUT it says it has 12 months MOT and for Ł425 that's a years worth of cheap motoring
