parts clear out erst low comp pistons etc
Just been clearing me shed of all my erst parts as car has now been sold so parts have no use to me some of them are brand new just never got round to fitting
series2 rs turbo fly wheel re faced 100 miles ago £25(sold)
17" 100+ 5 spoke alloy size 7j e38 good tread on tyre but got nail in it ideal spare £35
pair front std erst springs £5
erst t3 exhaust manifold with heat wrap £15
+1.5mm low comp cvh cosworth racing pistons approx 7.8.1 compression ratio fitted with recon std rods and arp rod bolts.These pistons have only done 100 miles due to loss of oil pressure due to wrong size bearings being fitted
from useless engine builder
i have the bill for £539 for pistons i then payed £100 for rods and £80 for arp studs + machining costs these owe me a lot of money so im after
£350 can also supply block and crank too if required
for a little extra....(sold)
Stainless fuse box cover £25
stainless wiper motor cover £25
stainless battery cover £5
stainless coil cover&bracket £7.50 (sold)
88 spec smooth polished charge carrier £20
ferodo racing brake pads series2 fitment £15
twin piston dumpvalve £25
erst t3 turbo metal water pipes painted silver with brand new banjo
bolts&washers £35
stainless suspension strut tops £7.50
erst braided injector pipes brand new £50 (sold)
haynes cvh engine building book £5
mk4 escort haynes manual x2 £5 each
erst mfi coldstart valves x2 £5 each
pics will be added later on all prices are collection only postage will be extra....
cheers
jon
£350 can also supply block and crank too if required for a little extra....(sold)
bolts&washers £35
cheers
jon
cool. if you still got them i'll have the pistons off of ya mate. i'm in peterborough so can pop across and pick em up next weekend if thats good for you.
regards tom
regards tom
regards tom
regards tom
