sounds like a diesel clatter, any ideas????
Old Jul 9, 2006 | 09:23 PM
scotty86d's Avatar
scotty86d
Default sounds like a diesel clatter, any ideas????
Sounds like a diesel on startup for the first 2 seconds then goes to normal. than in 1st 2nd and 3rd from 2-3ishk rpm i can hear a diesel kinda clatter and above that ist is just exhaust noise so cant tell if it gets worse. Its had a new head put in and i tried my best to bed the cam in ok. Smokes under load and im assuming thats pistons rings and the fact it hasnt been set up properly yet(maybe some overfuelling,set up due weds)
any ideas what the clatter could be?Also is there a gasket from manifold to turbo cos my join there leaks air.
thanks
Old Jul 9, 2006 | 09:37 PM
Rick's Avatar
Rick
No manifold betwee turbo and manifold, the faces have to be completely clean and true.
The noise could easly be ur airleak. What u describe does sound a lot like a broken ring land...
Old Jul 10, 2006 | 09:53 AM
scotty86d's Avatar
scotty86d
Wicked really wanted that to be the problem, got nothing left over money wise now. Going to save to rebuild my mondeo zetec then it seems and just drive this gently for as long as possible.
Old Jul 10, 2006 | 10:08 AM
Rick's Avatar
Rick
if it is a broken land, u an do 000's and 000's usually before it eventually breaks the ring, and u loose compression.
davidfordrs
Sep 21, 2015 04:23 AM
rogerxr3i
Sep 13, 2015 06:56 PM
fordfiestamk3
Sep 11, 2015 12:52 PM
Rizlablue
Sep 6, 2015 09:58 AM
Bighandsuk
Sep 2, 2015 05:23 PM
