suspension whats best for road use
suspension, need a new suspension set up on a budget dont do track days do i realy need adjustable or non . also how does 40mm look and on a s2 with standard wheels please help
Spax are a very hard ride with not much give in them at all, Koni's will be your best bet mate, adjustable's would be better as you can obviously adjust the ride to suit how you like it.
A 40mm drop on 15's will be very low, i'd usually say only go to about a 25mm drop at the most, too much and the RST's don't really respond to much from it
Get some Cobra springs from APT, i'll be getting them asap and just sticking with a 25mm drop, but i've got a Series 1
Originally Posted by telhonda1
nice one, cheers for the advice i will be getttung konis on 25mm very shortly thanks again
I would also buy new rubber mounts for the shocks from ford - 15 year old ones will be pretty battered!
Let us know how you get on
SMILER258
Sep 28, 2015 09:04 AM
