Lydden Hill (kent) trackday, 22-7-06, £120
I'm going in my xr2tt, fitted with slicks.
My brothers going in his pulser,2 mates are going in thier Pulsers, and a mate in his RST. Also a mate in his Mk3 escort 4x4 cossie if its fixed.
Always a Top Track, and Day. and slow - fast cars.
Places still available
Speak to Pauline @ Lydden track on 01304 830557
Had a Good day,
Car behaved, except a few little problem, i run a 51.39 PB on my lap timer in my tt
Fuel surge on left hander, so only half throttle could be used till half way up the hill,
Tyres werent warming up till the last couple of laps of the session
Coolant temps too high allday.
But understeer was very present, My brother was also doing it in his Pulser, But on the last session he took mine out, and couldn't believe the amount of under steer, (as he always sed his has bad underesteer)
I got the pressure's correct after the 4th session, so the tyres were even temps across the tyres ( or well as even as they would get)
But suspension needs changin,
i was running
1mm toe in, 1.5 neg camber and 3 positive castor on front.
1/8 neg camber (need to chop rear beam to adjust this, and i run out of time) and 1mm toe out on rear.
Tyre temps showed the inside of the tread was running 5 - 6 degrees hotter on both fronts, and o/s rear.
So i need more castor on fronts and more camber on rear.
Tyre pressures hot were
F n/s 27psi, 18.5psi cold, temps 73-79oC
F o/s 24psi, 16psi cold, temps 71-77oC
R n/s 23.5psi, 20psi cold, temps all 51oC
R o/s 21psi, 17.5psi cold, temps 45-49 oC
i was running
Sounds like you had a good day
When i was following a 4x4 saph at Brands & pushing a bit he started to suffer with understeer but in my 3dr just a small amount of oversteer but nothing like the understeer the guy in the 4x4 was suffering, we both used the same R888 tyres. Prefer rear wheel drive for drifting round clearways
Simon.
Simon.
nico12
Dec 31, 2015 04:42 PM
