central locking help. rick, safe chav????
Old Jul 6, 2006 | 03:20 PM
scottbrown's Avatar
scottbrown
Default central locking help. rick, safe chav????
I have a really irrating problem. every now and again when i lock the doors the locking opens its self again as though a door is open. I have tried other motors that are known to work and the same happens. problem is that when it does do it i cant lock the car. and sometimes it a day till it starts working properly again. any ideas as to what to check?
safe chav?? you good on electrics.. any ideas?
cheers guys
Old Jul 6, 2006 | 05:47 PM
PeterD's Avatar
PeterD
i had this prob on my old 306, solenoid was knackered. might be of use to give it a check but if you tried other motors then you will have.
sorry dude
Old Jul 7, 2006 | 07:24 AM
HORNETS7's Avatar
HORNETS7
TRY PUTTING WD40 IN ALL THE LOCKING MECHANISMS AS THEY STIFFEN UP AND THE SOLENOID CANT LOCK IT SO IT AUTO UNLOCKS
Old Jul 7, 2006 | 09:15 AM
SafeChav's Avatar
SafeChav
Firstly what car is it?
And do all the locks on all the doors lock freely from inside (try each one by hand)
Old Jul 7, 2006 | 11:52 AM
marky_g's Avatar
marky_g
Fleet Manager
maybe its how ur doors hung?????
Old Jul 7, 2006 | 01:48 PM
SafeChav's Avatar
SafeChav
To be perfectly honest the only thing that can make the central locking do that, are the front door mechanisms & motors, and wiring between them.
Rear doors and tailgates wont cause it. I personally would say the door looms are breaking down.....
Old Jul 7, 2006 | 02:31 PM
scottbrown's Avatar
scottbrown
89 escort rst turbo.
safe chav..
how can i check the loom?
cheers
Old Jul 7, 2006 | 02:35 PM
SafeChav's Avatar
SafeChav
Firstly check all the locks are free moving and not seizing up, and then check all the connections inside the door, and if possible give the terminals a tweak with a little screw driver to tighten them up.
If it is the door looms, u coudl try continuity testing but being an intermittent fault you're not guaranteed to get any results. You could just pull the rubber sections out and see if theres any broken/shorting wires inside which i bet there is.
Old Jul 7, 2006 | 10:51 PM
Rick's Avatar
Rick
It's the alignment usually that causes this. What you can try, is loosening the 3 torx bolts that hold the door catch in place, and adjusting it slightly. May have moved slightly. And as chav says, if the mechanism is stiff, that will cause probs.
Old Jul 8, 2006 | 04:01 PM
scottbrown's Avatar
scottbrown
u diamond
just looked... i only have 2 bolts in mine..
will get another bolt and try it.
cheers mate
Old Jul 8, 2006 | 04:40 PM
SafeChav's Avatar
SafeChav
u diamond
cheers mate
what are you like
2wdsaph ben
18
Oct 2, 2015 05:18 PM
muzzman1
Sep 30, 2015 08:59 PM
rsguy
44
Sep 29, 2015 03:29 PM
