turbo sizes - again!
im sure this has been on before but i cant find the answer doing a search.
my turbo says A/R 60 on the compressor and A/R 48 on the exhaust housing. it also has a 360 bearing and the compressor blades are bent back a bit (i guess this is 'cut back'?)
is this a t3 a t35 a t34 or a hybrid and how many hp etc is it good for? do i need a bigger exhaust housing or summit for more gee gees. stu is mapping it soon and i need to tel him what in it.
any help appreciated
thanx karl
what can i do for more power. it kicks in at 3500, the engine build can take more etc but how much will a change make to the power band. the engine has ahmed bayjoo spec cams in.
do i simply change the exhaust housing?
Leave it well alone.
A 0.48T34 is one of the best setups you can run on a YB. I personally don't rate using the larger 0.63 ex housing on a T34. For the extra lag it gives there are better turbos out there, but a 0.48T34 peaking at 2 bar and holding 1.7 will give super punchy lag free drive and best of all will be reliable and drivable!
considering the inlets ports have been opened up and the change of cams and 7.2 pistons + grey injectors; will this increased braething allow for more than the 350hp you mention as 350bhp appears to be the result of 803s and a 3bar map sensor. have i wasted money on 7.2 pistons for this engine if i use this turbo?
cheers
cheers
Matt Baxter
Sep 16, 2015 08:30 PM
lee2cossies
Aug 26, 2015 10:04 PM
muz
Aug 16, 2015 12:57 PM
