Managment
Old Jul 3, 2006 | 10:42 PM
rsspeeddemon's Avatar
rsspeeddemon
Default Managment
I am unsure what engine managment to use on my series 2. What do you all use or what would you recommend please?
Old Jul 3, 2006 | 10:47 PM
gus's Avatar
gus
t6 2000 on mine
use to use a p8
Old Jul 3, 2006 | 11:08 PM
NEWTON's Avatar
NEWTON
im just having gotech fitted to mine at jamsport,Ł950.00 plus the vat
Old Jul 3, 2006 | 11:44 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Omex 710
Old Jul 4, 2006 | 07:25 AM
ldack's Avatar
ldack
gotech!
Old Jul 4, 2006 | 08:00 AM
rsspeeddemon
I have heard a bit about gotech. And also megasquirt. Its surpsrising what there is on the market. Do any of the systems ahve theri own trick or unique apsects to the sytsems, ie water injection for example?
Old Jul 4, 2006 | 09:30 AM
reality's Avatar
reality
Pectel T2. The best a man can get!
Of course you'll have to convert your car to proper EFI too with any of these ecu's..
Old Jul 4, 2006 | 11:45 AM
ldack's Avatar
ldack
Gotech can do quite a bit, launch control, lamda etc. if you wanted
Look on therwebsite, has full details.
Old Jul 4, 2006 | 07:38 PM
stuart collins's Avatar
stuart collins
does water injection?nitros control can b wired up to do full throttle gear change , the new 1 does boost control and anti lag aswell
Old Jul 4, 2006 | 08:41 PM
reality's Avatar
reality
You shouldn't judge an ecu by how many bling features it has.. It's how well it controls that engine that is paramount.. I guess it depends on if you want a nice car to drive or something to talk to your mates about in the pub..
Old Jul 4, 2006 | 08:49 PM
iamrab's Avatar
iamrab
see this is a question that i wanted to ask as well ...by why do u need it ? and whwats the big advantage of having it?aslo whats the max hp that an rst can run with out it?
Old Jul 4, 2006 | 09:36 PM
reality's Avatar
reality
The KE-Jetronic metering unit chokes at about 230bhp (whatever you may read, power wise).. with a choice fuelling hacks you can reach this point..
Old Jul 4, 2006 | 09:43 PM
rsspeeddemon
Ok, so now we can see theres several options available. Whats the difference in cost between them all? Are they roughly the same, can you plug the mgmt into a laptop yourself for example and have some skullduggery fun?
Old Jul 4, 2006 | 10:27 PM
nigel b's Avatar
nigel b
i would personally choose the tuner your going to use first
ask them what management systems they can map and then decide from there
Old Jul 4, 2006 | 10:37 PM
reality's Avatar
reality
Old Jul 5, 2006 | 09:07 AM
rsspeeddemon
theres many tuners on the scene also. I guess by where i live i can choose between Carl Norris or PJ motorsport. I also have read a lot about stu from here.
Who does your motors, or who would you personally recommend?
Old Jul 5, 2006 | 07:29 PM
steven botes's Avatar
steven botes
try mr turbo or dicktator from RSA - check the web
both units are around ZAR2,100.00
fully tunable every 250 rpm , built in boost sensors , enrichment screw
some guys here running 500kw on wheels
plug in your laptop and away you go - may need to fit efi manifold from fiesta
Old Jul 6, 2006 | 09:17 PM
DazC's Avatar
DazC
Originally Posted by gus
t6 2000 on mine
use to use a p8
Bastard!
Old Jul 7, 2006 | 11:49 AM
marky_g's Avatar
marky_g
Fleet Manager
yer i was also thinking of converting to efi, would u need to do that any way ti run aftermarket managment????
Old Jul 7, 2006 | 05:12 PM
andre_k's Avatar
andre_k
jamsport, northampton do Gotech amongst others 01604 755529
also have a rolling road
ring and ask for jamie
cant go wrong with him
Old Jul 7, 2006 | 07:22 PM
reality's Avatar
reality
Yes.
mk3ste
Oct 17, 2021 10:09 AM
tankybaby66
Feb 6, 2016 02:24 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
griffo69
Oct 4, 2015 11:58 AM
deathrider666
Sep 28, 2015 06:12 PM
