wheels
Old Jul 2, 2006 | 09:30 AM
rsjonesy's Avatar
rsjonesy
Default wheels
hi just wounderd if any 1 knows what other wheels will fit on a vauxhall other then vauxhall wheels them selves many thanks for any replys.
Old Jul 2, 2006 | 11:47 AM
cossyjay's Avatar
cossyjay
hi there
you have to be carefull when changing vauxhall alloys
as they have a weird off-set and if it isnt right can lead
to all sorts of clearance problems hope this helps a-bit
cheeRS......
Old Jul 3, 2006 | 07:57 PM
tsrtrocse's Avatar
tsrtrocse
as above really. off set changes across the manufacturers so just be care full with it. but the answer to your question.
The stud pattern is the same for all the other makes apart from ford and peugeot. ford and peugeot have a 120mm stud pattern and the rest have 108mm. distance from the next adjacent stud or bolt hole.
Put it this way, i know of someone that had mg zs wheeel on their renault 19. all they needed to do was change the size of the very centre. the bi that goes over the hub.
hope that helps you out.
Fiddy
21
Sep 29, 2015 06:10 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Karl @ FPT
Sep 21, 2015 11:17 AM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
Adam Graham
Sep 6, 2015 06:04 AM
