lambda sensor issues
Old Jun 30, 2006 | 09:19 AM
Badman38's Avatar
Badman38
Default lambda sensor issues
Can any one tell me the symptoms when the lambda sensor goes wrong? I am running closed loop on a s8 ecu and the car was running rich with an erratic idle, i have checked things like map sensors, ignition amps, how can I check the lambda sensor functioning? , there are four wires on the lambda sensor the grey wire was wasn’t connected but when I connected this wire thinking that it maybe positive but the car cut out on doing this… is this the right wiring sequence. Black = ecu sensor wire number two on the port ecu plug. Two white one = positive the other white plus grey = negative.
Thanks
Sean
Old Jun 30, 2006 | 09:40 AM
kjc300's Avatar
kjc300
If the lambda is functioning then you will be able to see it on your S8 software flipping from rich to lean etc??
Old Jun 30, 2006 | 12:31 PM
Badman38's Avatar
Badman38
thats the only problem at the moment my laptop gone tits up
Old Jun 30, 2006 | 12:51 PM
kjc300's Avatar
kjc300
Ah, bugger!!
Well the S8 only needs one wire from the lambda and thats the signal wire to pin 2 on the ecu. The sensor itself needs a pos and neg for the heater. As for a 4 wire lambda, the other wire is probably signal ground so just earth it to the other neg wire? You probably need to find out what make your sensor is and do a search for wire colours/jobs. The signal wire off my 3 wire one is white!!!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
