Help with brackets for pace intercooler....
Old Jun 29, 2006 | 02:26 PM
spadey's Avatar
spadey
Default Help with brackets for pace intercooler....
Ok so IVE had no luck with finding any brackets to move the fan over to fit the intercooler so was wondering if anyone had a picture of a bracket or somethig so I could copy it? Any ideas are gladly welcomed.... Also how do I remove the bumper????
Old Jun 29, 2006 | 03:16 PM
antony215's Avatar
antony215
Escort Rs Turbo
The three brackets you need to make are in the picture
http://paceproducts.co.uk/php/produc...scortrsturbos2
Old Jun 29, 2006 | 03:25 PM
spadey's Avatar
spadey
Default re brackets
Thanks mate but I really need sizes I suppose. Ive been told I can get away with just moving the fan over and it should be ok, do you know if this is correct? Also how do I remove the bumper so I can look at it? Cheers
Old Jun 29, 2006 | 03:35 PM
antony215's Avatar
antony215
Escort Rs Turbo
There are 4 bolt's(13mm) two that you can see and get to from the engine bay on each side by the light's and two that you need to put your hand up inside the wing's to get to and two screws on each side of the bumper that screw to the wing's. You need to move the fan over anyway to fit it so thats got to be moved over
Old Jun 29, 2006 | 04:01 PM
spadey's Avatar
spadey
Default re brackets
Thanks for that mate, so if I get the bumper off do you think I will be able to work out how to move over the fan? Obviously if I put the intercooler in then I will know how much ive got to move it over? The bolts that hold the fan on originally can I not just relocate them? Cheers
Old Jun 29, 2006 | 05:24 PM
scotty86d's Avatar
scotty86d
the fan has to be right over for the intercooler to fit and i second that about the relocation
Ridgey
12
Nov 2, 2015 06:54 PM
Nov 1, 2015 06:53 PM
155lee
Oct 27, 2015 04:55 AM
The Youth.
Sep 30, 2015 09:59 PM
