Trader Parts for Sale. Only Registered PassionFord Traders can sell parts in here. Buy with confidence.
Attention all WEBER ECU Owners.. NEW PRODUCT!!
Old Jun 28, 2006 | 06:00 PM
Stu @ M Developments's Avatar
PassionFords Creator
Default Attention all WEBER ECU Owners.. NEW PRODUCT!!
https://passionford.com/forum/viewtopic.php?t=206547
Old Jul 5, 2006 | 01:30 PM
sygjim's Avatar
sygjim
Old Oct 16, 2006 | 06:55 AM
BTTT
Old Nov 6, 2006 | 05:53 PM
Old Nov 7, 2006 | 02:52 PM
sygjim's Avatar
sygjim
in the future, it would be possible to datalog the lambda ?
Old Nov 17, 2006 | 12:09 PM
gingeRS's Avatar
gingeRS
is this simple to use?
ie install on laptop, plug into ecu (via where?) and it will fault find all wiring and sensor problems?
like an advanced secs monitor
how eaxctly, does it plug into the ecu? as there is no obd port on a saff?
Old Nov 17, 2006 | 12:20 PM
sygjim's Avatar
sygjim
you need a serial cable to plug between the diag and the pc
it will show you errors but you need to have the pectel datastream enable on your chip
i think (and i hope) that it's very simple to use
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
sridgett
Oct 1, 2015 07:30 PM
