brake calipers
The question is about the calipers....
I can put anything from 240mm (as above) upto 305mm on them - so measuring the disc is pointless.
The size of the piston inside the caliper will tell you.
ESCORT Mk3/4 1.1, 1.3, 1.4, 87-90 fronts are 240mm x 24mm
ESCORT 1.6i, XR3, XR3i 84-90 fronts are 240mm x 24mm
ESCORT RS TURBO S1 85-86 fronts are 240mm x 24mm
ESCORT RS TURBO S2 86-90 fronts are 260mm x 24mm
XR3i discs will fit with S1 RS TURBO calipers - which those could be
looks like an S2 to meeeeeeeeeeeeeeeeeeeeeeeeeeeee
i measured the disks today and there 240mm
could i put bigger disks for a s2 on or would i need ones to fit a s1 and whats the difference with the pad size is there any
)You could get some S2 calipers and discs, i believe the S2 calipers are also found on the 4wd sierra's...
so apart from the piston size whats different with the calipers cause i thought they looked the same, could i put disks and pads to fit an rs turbo with these
The caliper also is physically bigger to allow the bigger discs, if you try and put bigger discs on with your current ones they will foul, so you would need brackets to relocate them
