chipping / setting up 1.8zvh
anyone reckonmend the best way to go about this?
am building up a car at the mo, to which i am fitting a 1.8zvh turbo, spec is:
1.8zetec bottom end with skimmed standard pistons (am told its safe at 12psi boost)
cvh efi turbo head, recently fitted with a new piper cam (by SCC) but head standard other than this
standard t3 turbo
ofab management
havnt got the intercooler yet, will be a front mount or pace type, depends what comes up!
as you can see, not exactly a mad spec, just want reasonable power and drivability at this stage, with a view to upgrading in the future. So what are the best options chip and setup wise, I am in welwyn garden city in herts, so close to SCC who have done a topo job setting up cars for me before. Will a standard chip then a setup be any good (ie a 165 or 195 chip) or do i need a custom map?
thanks in advance
standard t3 turbo
ofab management
thanks in advance
You'll need a chip for that particular spec.. Someone like Ahmed Bayjoo should be able to sort you out a relatively off-the-shelf chip for an 1800cc, a set of injectors and a map sensor that'll do the trick..
Steve Escos
Ford Focus ST Parts for Sale
Sep 2, 2019 11:39 PM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
