Sierra Cosworth ABS Brake servo dimensions?????
Old Jun 25, 2006 | 08:27 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Default Sierra Cosworth ABS Brake servo dimensions?????
Can someone plaese measure the following on a sierra ABS electric pump/servo unit.
Width at widest point
Height
Length (from the bulkhead mating face to the furthest point)
Old Jun 26, 2006 | 05:32 PM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
Sent on MSN, hope they help you matey
Old Jun 26, 2006 | 05:38 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
Si, can you post up here aswell please mate, i think i need to know too lol
jst got my head back and fitted the roller barrels, they hang off the side of the head a good 12" and i still got to get a plemum made up to round em lol
Old Jun 26, 2006 | 06:13 PM
Si B's Avatar
Si B
No worries Dan, here's what I sent Gracie:
height inc resevoir that sits on top of it all - 31cm
height of everything other than resevoir - 19.5cm
width at widest point = 19cm
26cm deep from bulkhead to furthest point - which is a multiplug
Also for peeps using these where space is an issue:
2wd and 4 x4 resevoirs / pumps are different - they are mirror images of each other - the resevoir is on one side or the other depending on model - so while a 2wd one may fit, a 4x4 may not and vice versa.
Regarding the plenum, we'd love to make one up for you, but have put these on the back burner for now due to concerns over ensuring even flow (although I've now seen several working versions that are basically just 'boxes' with no ill affects to the cars they were on.)
The one on my own car seems to be doing the job nicely as well!
Hope the dimensions help
Si
Old Jun 26, 2006 | 09:05 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
cheers Si
original
Apr 28, 2026 05:20 PM
charliecosworth
Aug 19, 2015 02:00 PM
c20tbo
Aug 17, 2015 10:19 PM
cossie4x4
Aug 14, 2015 06:29 PM
Jack and the Beanstalk
Aug 9, 2015 07:03 PM
