Actuator rod keeps snapping....Please help
Old Jun 25, 2006 | 03:34 PM
Beach's Avatar
Beach
Default Actuator rod keeps snapping....Please help
My actuator rod keeps snapping on my -34 on my 2wd saph, second one snapped today and yesterday the actual bar snapped that goes down to the wastgate
TBH i think theres somthing wrong with my turbo damper as it doesnt seem to be doing much.
Any help would be fantastic
Old Jun 25, 2006 | 03:37 PM
Fiecos Dan's Avatar
Fiecos Dan
How much preload you running??
i cant see the turbo damper causing this.
Any pics of your turbo fitted??
Old Jun 25, 2006 | 03:40 PM
Beach's Avatar
Beach
I do run quite a lot of pre load on my actuator tbh and i do realise this is most likly the cause but im just curious
Old Jun 25, 2006 | 04:07 PM
DazC's Avatar
DazC
Had this happen before. It was down to a bent actuator bracket.
Old Jun 25, 2006 | 04:29 PM
Stu @ M Developments's Avatar
PassionFords Creator
T34 by any chance? If so its very common and its due to a resonant frequency clash of teh front and rear wheels.
Fix is simple, Fit teh correct actuator.
Old Jun 25, 2006 | 04:45 PM
Fiecos Dan's Avatar
Fiecos Dan
That was why i wanted to see a pic,
As for best boost controll, the actuator needs to mounted as straight as posible to the wastegate, and so wen it opens it moves in the direction of where the wastegate needs to go.
Old Jun 25, 2006 | 04:50 PM
cossiecrew's Avatar
cossiecrew
the actuator was what turbo technics supplied along with the t34 i *THINK* so surely it is the right one
Old Jun 25, 2006 | 04:51 PM
Well, is it the right one or not?
Old Jun 25, 2006 | 04:53 PM
cossiecrew's Avatar
cossiecrew
well the 1st one snapped and that was the one that came with the turbo lets say not sure about this one but the 1st one was
Old Jun 25, 2006 | 05:07 PM
So it looked like this did it?
very short shaft?
Old Jun 25, 2006 | 05:20 PM
Beach's Avatar
Beach
No its got a fairly long threaded shaft and is just a standard -34 to suite the 2wd turbo setup, as supplied by turbo technics.
Turbo damper wasnt working correctly as one of the discs was damaged and this may have not helped with vibration.
Ill go and have a look at the allignment of the actuator
Stu what do you mean about correct actuator ??
Old Jun 25, 2006 | 05:29 PM
The correct actuator for the T34 is teh one shown above, and it is used for teh reasons i stated initially. Tests show that the snapping is due to a HF issue on SOME installations and it almost always shears directly where the nut is tightened up.
The long term cure was to do what garret did and extend the actuator rod so the point of the HF clash was thicker and stronger steel.
Old Jun 25, 2006 | 05:36 PM
pee vee's Avatar
pee vee
is it a garret actuator though
Old Jun 25, 2006 | 05:37 PM
pee vee's Avatar
pee vee
is it a garret actuator though (the snapped one that is)
Old Jun 25, 2006 | 07:10 PM
GARETH T's Avatar
GARETH T
garret make different actuator rod legths for different turbos,,, even though they got the same lift rate
Old Jun 26, 2006 | 02:49 PM
Beach's Avatar
Beach
Ill take some photo's now when i take it off....
Turbo technics are sending me a new one in the post but im going down in my car as its getting on my tits quite a bit now !!
Old Jun 26, 2006 | 04:51 PM
cossiecrew's Avatar
cossiecrew
answer your phone you gimp
steve.rst
Mar 15, 2016 08:01 AM
A.t.p
Sep 29, 2015 05:04 PM
little bram
Sep 27, 2015 07:45 AM
rs_jim
Sep 19, 2015 08:41 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
