L8ecu do they all have babyboards as standard?
Old Jun 25, 2006 | 03:20 PM
costina's Avatar
costina
Live long and prosper!!
Default L8ecu do they all have babyboards as standard?
just wondered as i got one without board,and others i have seen don't have one too
got an MSD closed loop chip and need to know if i need one of these boards to run it ?or do i just plug into main board?
cheers
Old Jun 25, 2006 | 03:28 PM
pee vee's Avatar
pee vee
HTH pics of my L8 before and after msd closed loop chip
assume it was all standard apart from the chip that EA put in
Old Jun 25, 2006 | 04:25 PM
ECU Monitor Enthusiast
Yes they do come with a board as standard.
Old Jun 25, 2006 | 04:30 PM
Stu @ M Developments's Avatar
PassionFords Creator
Yes they need the board. Its virtually a L6 without it.
Old Jun 25, 2006 | 04:32 PM
Stu,
You shouldnt have said that.
Just wait for people to post if they can convert L6 to L8 by using a
standard babyboard.
Old Jun 25, 2006 | 04:39 PM
richm's Avatar
richm
Originally Posted by SECS
Stu,
standard babyboard.
.. so what's the answer Si..?
Old Jun 25, 2006 | 04:42 PM
No
Uses the same processor but the memory and I/O map is different
and of course you have the lambda sensor interface on the L8
which isnt on the L6.
Old Jun 25, 2006 | 05:29 PM
costina's Avatar
costina
bollox how much for one of these then?
cheers simon and cheers stu
simon ur L8 chips u supplied me a year+ ago are plugged on standard board and work my mates produced 336bhp on a standard lump at 22psi why would this b if u need a baby board to run them??????????
very very confused now
Old Jun 25, 2006 | 05:33 PM
The baby board is an inegral part of the L8 ecu and is a design after
though by the manufacturer (weber marelli).
It is NEEDED.
The chips I used to supply were simple modified versions of the original
program fitted to the car and so work on the ecu as supplied.
I.E. with the original baby board
The baby board is simply a memory expander as the software on L8
is much more complex than the L6.
The golden rule of all programmers is to fill all available memory even if
it isnt actually needed.
Old Jun 25, 2006 | 05:47 PM
costina's Avatar
costina
so i need a standard L8 babyboard then?
oh well its only money
Old Jun 25, 2006 | 08:18 PM
costina's Avatar
costina
sorry werea my manners
THANK YOU pee vee
Old Jun 26, 2006 | 01:22 PM
costina's Avatar
costina
pee vee ,what spec are you running and what power did you have?
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
SMILER258
Sep 28, 2015 09:04 AM
