Spark plug broken up? but AFR perfectly safe.....
My Brothers Pulser started to miss fire yesterday,
But before hand had been running fine all week, and last time it was booted was 2 fridays ago.
So he removed the plugs, and the tip was missing on cyclinder 1 plug
And we know its running 11.8 - 12.0 :1 AFR, as he's got a wideband fitted, and he sed he was watching it last time he gave it some wellie.
And there's NO DET at all.
He's running HKS plugs, which he's never dropped or damaged them in any way.
Has anyone had similar problem?
All i can put it down to is a faulty plug, or injector is failing.
How does your brother know that 12.0 is a safe AFR on his engine?
What EGT does that result in on his car?
As gareth says though, probably just the wrong plugs.
Try a set of 071 if they are the same fitment, those bad boys seem to work in everything
Cheers Gareth / Chip
EGT's are under 800oC by memory.
Its a GTIR, running std turbo,
1.2 bar boost, with unrated MAF, inj, Apexi boost and fuel controller.
So about 300 -330bhp, so its not mega power, So 12.0 is fine.
Sounds perfectly safe to me too then mate.
I'd definately look at the plugs themselves then, either its a diff one or the wrong heat rating.
How do the other 3 look?
Number 2 is the one that sits nearest the turbo on a pulsar isnt it?
(so will be slightly hotter)
I haven't seen the car, So i'm going by whats he's telling me,
But i beleive No1 is normally the one that goes down.
I've just spoke to him, and its 11.8 all way thro, but hit 12.2 for a split second then back to 11.8:1.
He's also using rating 8 HKS plugs, which he says are used on alot of the 400 bhp pulsers.
cheers, but can't see that, as no real load, so no real Temp,
14.0-15.0:1 i think he sed. with EGT's of 450 oC
Which i cant see being a problem, as i run 15.0 on my cars,
Originally Posted by Christian and Beccy
I think the HKS plugs are the made by Denso. If so, Denso's have a habit for dropping the tip off, in Nissan engines.
Use NGK Iridums IMO.
Have you seen happen on one of your customers cars??
Originally Posted by Bosch-Man
...yes the denso plugs have a habit of tips dropping off...the main reason is they are not meant to be gapped from how you buy them!
So regapping them, weakens the tip?
I've told him to bring the car round,
and i'm gonna try some ford plugs for fitment.
Cant believe these plugs are that weak, i've regapped plugs (ngk, champions) tens of times, and never failed
deathrider666
Sep 28, 2015 06:12 PM
