zoo motorsport clutch cables
stronger than the ford motorsport ones brookling and ggr used to sell NO MORE SNAPPED OR MELTED CABLES !!!!manually ajustable with added 1500 degrees c fire retardent sleaving
£86 deliverd
can make cables to diffent length aswell
pedle kit for above £65 exchange
£86 deliverd
Cheers mate
the length will be the same as a normal Cossie I think,just need the pedal end of the cable to have the fitting on it for a Capri pedal instead of auto adjuster. And the fitting into the bulk head the same as a Capri. Cheers for any help mate
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
