escort s2 clutch pedal
hello all i have 89 s2 and want to fit the mark 5 clutch pedal i have done a search and posted in rs turbo but no ones replied.basically what bits do i need? and is there a step by step quied on doing this.where do i get the parts from(scrappy or ford??
Hello James The info you need to know is at AP Racing : http://www.apracing.com/roadcar/clutch/epmods.htm
They give you all the pictures and part numbers of the bits you need from ford (you can order the bits from ford
) and tells you exactly how to modify it. Hope thats a help
If you still have RST "RPO" then it had a AP2000-8 organic clutch fitted and new clutch cable, if thats any help
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
