200bhp ?
Old Jun 24, 2006 | 11:08 AM
White RS1600i's Avatar
White RS1600i
Default 200bhp ?
What exactly is needed to see 200bhp on a efi 1600cvh with a t3 ?
Old Jun 24, 2006 | 12:18 PM
BRAMMER's Avatar
BRAMMER
For starters a good condition engine - Chip - Air filter - T3 - -31 acuator - Stainless - Front Mount Cooler or uprated - Uprated fuel pump - Beige injectors, good plugs and leads and you will then need a decent clutch and go for a escort turbo box.
Thast would be an excellent start
Old Jun 24, 2006 | 12:33 PM
White RS1600i
cheers mate, so fairly easy ?
Old Jun 24, 2006 | 12:45 PM
jrs's Avatar
jrs
But not cheap
Old Jun 24, 2006 | 02:58 PM
White RS1600i
Is it worth just going straight to cossy management instead of faffing around with fez ?
Old Jun 24, 2006 | 03:09 PM
Oranoco's Avatar
Oranoco
Nope,
If your going to faff about and have the expense of a new management system you might as well get brand new up to date kit. Cossie management conversions are rapidly becoming old hat now the cost of new kit is coming down.
My brothers FRST and my own are 200bhp cars and both are still on stock management with chips. In fact my bro's was set up this morning and gave a safe 211bhp
Old Jun 24, 2006 | 04:10 PM
White RS1600i
Sounds good mate with what mods exactly ?
Old Jun 24, 2006 | 04:19 PM
Oranoco's Avatar
Oranoco
Mine
207bhp at Engine Advantages
Stage 2 T3
Magnex exhaust
Induction kit
Beige injectors
Chip
Chargecooler
Bro's
211bhp at SCC Performance
Stage 2 T3
Induction kit
Pace intercooler
Kent CVH 35 cam and vernier
Beige injectors
Cossie fuel pump
Mongoose exhaust
Boost mod
Old Jun 24, 2006 | 04:55 PM
White RS1600i
What the boost mod ?
Has anyone got a full 200bhp kit for sale ie chipped ecu injectors etc. I would just rather buy it all in one than get bits here n there.
Ive just been looking on ebay for second hand goodies. So basicly is it just the injectors and chip i need ? Is it all plug and play or must it be setup ?
im just learning btw bare with me lol
Old Jun 24, 2006 | 05:15 PM
Oranoco's Avatar
Oranoco
It takes the feed for the actuator straight from the charge carrier rather than from the turbo housing so it holds better rather than peaking and then tailing off. My bro's boost is really sweet. Winds up to 21psi falls back to 19psi and then just hold it
Once fitted you will need to get it all checked to make sure all is well. It's highly adviseable to get the fuel pump changed as well though.
Old Jun 24, 2006 | 05:21 PM
White RS1600i
Cool, so not that much hassle to hit the magic number
If i budget say Ł300 all in that should cover the bits and a little setup ?
Old Jun 24, 2006 | 05:38 PM
Oranoco's Avatar
Oranoco
Wouldn't think so. What do you have at the minute parts wise?
Old Jun 24, 2006 | 05:50 PM
White RS1600i
Just a standard fez running a t3 with induction kit
Old Jun 24, 2006 | 05:57 PM
Oranoco's Avatar
Oranoco
Assuming you can fit all the kit rough prices for you.
Exhaust Ł280
Injectors Ł60 each (Ł240)
Chip Ł250
Intercooler Ł240-Ł450
Shell's Avatar
Shell
Pretty much the same as mine although i am half way through getting my parts...
Already on the car
Some dodgy 4" exhaust on the car already when i bought it
T3
Cone filter
I have waiting to go on the car
Pace intercooler
Motorsport leads
-31 actuator
I now need
Set of beige
Chip
Good set of tyres
Cossie fuel pump
Clutch
All before USC
Hope that helps x
Old Jun 24, 2006 | 06:01 PM
White RS1600i
Exhaust Ł280
Chip Ł250
Cheers bud no i ment second hand prices ive found
Injectors Ł120 buy it now
Chip Ł100 buy it now Brand new
Ive got an exhaust aswell so just and intercooler is needed. Im sure i could hit 200 with a standard cooler just with mental acts ?
Old Jun 24, 2006 | 06:04 PM
White RS1600i
Already on the car
T3
Cone filter
Pace intercooler
Motorsport leads
-31 actuator
I now need
Set of beige
Chip
Good set of tyres
Cossie fuel pump
Clutch
All before USC
Hope that helps x
Sounds good! I hope you have it done in time, im aiming to get mine sorted by usc aswell!
Shell's Avatar
Shell
Exhaust Ł280
Chip Ł250
Get an intercooler... there is no way round it...
Also... older and wiser people have always told me to buy injectors new... i'd listen to them x
Old Jun 25, 2006 | 09:35 AM
Oranoco's Avatar
Oranoco
200 is possible on the stock intercooler as I did it but it was in October last year and the ambient temps were low. It would have been a recipe for a dead engine in the summer months.
I got my injectors second hand but only as I knewand trusted the source.
Old Jun 25, 2006 | 10:18 AM
White RS1600i
What about a chip, would it be easyer to just a second hand chipped ecu or a chip ?
Old Jun 25, 2006 | 10:21 AM
Oranoco's Avatar
Oranoco
Second hand chips are such an unknown. Unless you can be sure of the seller/item I would buy a new one. Seen so many people unaware that there are two different types of management on the FRST
Old Jun 25, 2006 | 11:08 AM
White RS1600i
Cool mate let us know if any decent secondhand parts turn up as i would rather sorce secondhand parts than new.
Cheers mate
Old Jun 25, 2006 | 12:29 PM
BRAMMER's Avatar
BRAMMER
So here you have it a standard block and head, this is the advise and step i would take:
1) new plugs, leads, oil & filter, fuel filter and injector cleaner.
2) Book the car in for a tune on the rollers to find out the condition of the motor, if the engine has a good bill of health then modify as theres no point tuning a worn engine as increasing the boost pressure only increases engine work which can excelerate detonation.
3) purchase a stage one clutch at least
4) purchase a front mount cooler (they don't come around often for fiestas second hand, GRS Ł315 NEW)
5) If you buy second hand make sure the chip you get is correct as steve said above there are different types, and if you buy second hand injectors it may be worth getting them ultrasonically cleaned and tested as a bad injector can mean detination, then purchase a escort cosworth fuel pump, they are on ebay brand new for about Ł80.
6) Back on the rollers for a set up and then you may see the magic number safely, don't rush and cut corners it only ends in tears as we have all been there before.
Good luck and keep us posted
Old Jun 26, 2006 | 04:21 PM
Oranoco's Avatar
Oranoco
Originally Posted by Homer J Simpson
DOH!
Old Jun 26, 2006 | 04:45 PM
Sean_RS's Avatar
Sean_RS
Old Aug 20, 2006 | 08:53 PM
_DAN_'s Avatar
_DAN_
Yoon
Is it me or are these motors piss easy to tune?
Old Aug 31, 2006 | 12:34 AM
beef2001's Avatar
beef2001
Boost it
yeh they seem quite easy to tune, i got the T3 chip set up Im not bothering with the beige injectors, but I will get 200bhp im sure at some point. how do i know if its got the -21 acutator wat the hell does it look like?
Also ive heard the standard intercooler will only do for 12psi be warned!
Aparantly i got 3 cylinders with 125 and one with just 100 im told it might just be a sticky valve any ideas?
glenbat
May 31, 2005 06:36 PM
jason690
May 21, 2005 08:19 PM
skeld
Oct 27, 2004 09:54 AM
SteveT
Oct 7, 2004 03:57 PM
Dec 8, 2003 07:10 PM
