ERST Series 2 rear brake problem
Old Jun 24, 2006 | 12:20 AM
daviddunlop83's Avatar
daviddunlop83
Default ERST Series 2 rear brake problem
My friend took his car to get the brakes bleed and ford told him there was no brake fluid coming out the rear bleed nipple. Apprently they disconnected the brake pipe half way up the car and the fluid was coming out there ok an the front bleed fine
What is the most likely cause of the problem ??
Old Jun 24, 2006 | 01:15 AM
NUTS RuS's Avatar
NUTS RuS
rear load compensators u/s ??
Old Jun 24, 2006 | 06:04 AM
Rick's Avatar
Rick
make sure wheels are on ground when bleeding.
Old Jun 24, 2006 | 07:25 AM
starturbo's Avatar
starturbo
I second that.
Old Jun 24, 2006 | 09:54 AM
daviddunlop83
If it is the rear load compensators would this stop all fluid or just stop the brakes working properly? Could it be a blockage in the pipes or cylinders?
Old Jun 24, 2006 | 10:23 AM
Wazzzer's Avatar
Wazzzer
yes it would stop the flow of fluid to the rears if the back end was jacked up in the air
Old Jun 24, 2006 | 10:31 AM
Micky's Avatar
Micky
You'd think Ford would know this and be able to fix the problem!!! They must have monkeys employed in the garages these days!! Regards Micky
original
Apr 28, 2026 05:20 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
track.focus'd
Aug 12, 2015 05:53 PM
Bosch
Aug 4, 2015 05:14 PM
