1993 escort cosworth big turbo
I have got a 1993 escort cosworth big turbo. Dose anyone know which side of the boost control valve the pipes fit.One goes to the actuator and the other one goes to the turbo compressor.I have just noticed that it has never been conected,it has just been there.Many thanks. Kerry.
Hi Martin.Can you send me your eMail address and i can send you a picture when my son comes in.The eMail address that you need to send yours to is mikey_boy_2k5@hotmail.com. I am new to computors and don't know what i'm doing so my son has to do it for me. Thanks. Regards Tony
basically the compressor housing pipe is t'd into the wastegate pipe,this then goes to one connection on the amal valve and pressure is bled off through the other connection[white dot],the white dot one usually goes to airbox/filter,the escort one is diff to sierras
Escortdriver1
Jul 31, 2015 02:36 PM
