MERC GREY ESCORT TURBO LOADS MODS 2K (sold)
It’s a f reg mercury grey series 2 rs turbo 12months mot&4 months tax 130k mile but engine s not done that…
Exterior:
Smoked rear lights
90 spec front bumper
90 spec rear spoiler
Quad lights with inner lights removed and meshed
Bonnet raised&bonnet pins
Clear side repeaters
17”5 spoke alloys in gun metal grey
Koni FRONT shocks&springs (REARS STILL NEED FITTING)
Uprated brake discs&pads
adjustable rear tie bars.
New rear brake cylinders, goodridge braided brake pipes abs been removed.
Engine:
Bottom end,low comp mahle pistons running 7.8.1 comp done about 25k no knocks or rattles.
Stg3 burton power head&kent vernier pully running std cam
4x4 cossie turbo with .48 housing from saab turbo& -31 actuator
Full stainless mongoose exhaust 4” tailpipe
Grs front mount intercooler&slim line fan
super chip ecu running 15 psi at moment
Magnicor blue spark plug leads
Modified fuel ecu
New recon radiator 6 months ago
Modified air filter
Bailey oil breather
Full samco boost&water hoses
New starter motor&alternator 6 months ago
New fuel pump 6 months ago
Interior:
88 spec front recaros
4 point luke harneses
Stripped out rear with black flooring
Half show roll cage
Act gauge
Boost gauge,oil pressure gauge,volts gauge,oil temp gauge. (need wiring up still)
3 spoke rs steering wheel (slight wear)
Cd player & front & rear speakers
Had service 1 month ago new dizzy cap,rotor arm,spark plugs,oil filter and oil.
Cat1 alarm
It does need some bits doing still and could do with a touch up in places you best off coming to view it.if it does not sell whole it will be broken shame as its only just had mot done
£2000 no offers or part ex as need cash
prob few other bits but cant remember any questions just ask?
Exterior:
Smoked rear lights
Engine:
Modified fuel ecu
Modified air filter
Bailey oil breather
Interior:
Half show roll cage
Act gauge
Cat1 alarm
Originally Posted by Ad4m RST
what exactly needs doing?
would be up for a lot more if paintwork was mint....
