P8 ecu
Old Jun 17, 2006 | 10:45 PM
3dr wixsy's Avatar
3dr wixsy
Default P8 ecu
What goes to pin 9 and pin24
Old Jun 18, 2006 | 10:55 AM
richm's Avatar
richm
on a standard P8, nothing connects to 9 (may get used for other stuff with pectel modification etc) and 24 is the earth return side of the ignition amplifier trigger signal (trigger sig + on 25, trigger earth return on 24)
Old Jun 18, 2006 | 05:33 PM
barry0777's Avatar
barry0777
what about pin 26 12 do you also have the pin lay outs for a P8 if so pls mail me at babombrs200@hotmail.co.uk with thanks
Old Jun 18, 2006 | 07:37 PM
3dr wixsy's Avatar
3dr wixsy
Default pin nos
its just that i had a loom made to go dizzyless and the pins were for 26 and 24 but 24 was already used. Engine tuner said use 9 then but engine sparks when ignition turned on but no spark when its turned over.problems me things cos i know nowt about ecu,s
Old Jun 18, 2006 | 08:13 PM
richm's Avatar
richm
ah.. in that case... I'm not 100% sure so best to be asking Stu really, but..
Presumably you have a second ignition amplifier that has to be wired in?
It's quite likely that it will use the normal trigger output on 25 to trigger one amp and 26 (which isn't used on a standard P8 setup) to trigger the second one, with the ground return signal from 24 going to both.
At the ignition amp end the trigger signal (from 25 or 26) connects to pin 6 of the amp and the ground signal return (from 24) connects to pin 3 of the amp.
But please confirm with Stu or someone who has this setup, that it is pin 26 that is used for the second ignition amp trigger.
Old Jun 19, 2006 | 11:33 AM
Stu @ M Developments's Avatar
PassionFords Creator
I would ask teh tuner who sold you the parts as thats a wierd configuration he has suggested to you. I would rather not guess personally.
Old Jun 19, 2006 | 03:40 PM
markk's Avatar
markk
pin 9 has been known to be used for vairable boost control
Old Jun 19, 2006 | 03:56 PM
richm's Avatar
richm
Stu,
When P8 is used for DIS, is it normal to use 25&26 for the ignition amp trigger signals? I haven't looked but I suspect pin26 is populated internally the same as 25 as ignition amp trigger output? (L8 is too, but the components aren't fitted)
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
