Please help, no comp on a cylinder?
Old Jun 12, 2006 | 10:38 PM
Lo@der's Avatar
Lo@der
Passionford Thread Killer
Default Please help, no comp on a cylinder?
hi, I have no comp on cylinder 2 in the cossie.
I am told that you need these below for compression to be obtained , can someone verify this so I can tck them off to get to the problem. cheers.
Pistons & Rings
Valves
Head
Head Gasket
Bore Walls
Plugs
Old Jun 13, 2006 | 07:17 AM
HORNETS7's Avatar
HORNETS7
no compression is:
either a hole in your piston ( no compression)
knackered piston rings ( very little or no compression)
bent or damged valves ( no compression)
cracked cylinder head( u would get a little compression)
cracked bore wall ( u would get a little compression)
headgasket( u would get small compression)
doubt its the plugs unless its not seated right but u would hear it pop as the pressure would be good!
Old Jun 13, 2006 | 10:36 AM
Lo@der's Avatar
Lo@der
Only just did a head gasket on it so i know the following:-
bottom end is all fine no prob there ran perfcet before
Head was crack tested
Brand new 3 layer cometic head gasket(but will do tests on comp, water and oil today)
Valves , dont see how I could of only bent one or two plus it started running perfect again the other day after fucked follower was found, but then went back to shit again. So thats what made me replace followers, still no difference though?????????????
Old Jun 13, 2006 | 02:59 PM
HORNETS7's Avatar
HORNETS7
SOUNDS LIKE IT COULD BE A VALVE BENT THEN!
u say u had a fooked rocker which one was it one over cylinder no2?
Old Jun 13, 2006 | 03:55 PM
IANS2RST's Avatar
IANS2RST
it is possible to bend the valve just by having the weight of the head on it when it was on the work bench.
do a wet & dry compression test, this will tell u if the problem is with the head or not.
also did u know that both the block & head need to be perfectly flat for a cometic gasket to seal properly as the steel is not as forgiving to any distortion like the normal fibre group a gasket.
unless its a new build & u can deck the block as well as the head then use the reinz group a gasket.
Old Jun 13, 2006 | 05:44 PM
Lo@der's Avatar
Lo@der
I found the culpret, the valve seat had poped out , fuck knows how and bent an inlet valve on no.2 when it hit the piston. Not to bad really just frustrating plus I got a nice dent in the piston (no crack thank god).
Old Jun 13, 2006 | 07:17 PM
phil_focus's Avatar
phil_focus
i would replace that piston if i wos u because it will lower the compression in that cylinder and wont run right.
glad you found out the probs tho
Old Jun 13, 2006 | 07:36 PM
Lo@der's Avatar
Lo@der
Or maybe I should re shell it while Im at it because its got a bit dirty.
cheers anyway m8
Old Jun 13, 2006 | 07:48 PM
phil_focus's Avatar
phil_focus
Old Jun 13, 2006 | 09:45 PM
HORNETS7's Avatar
HORNETS7
glad u sorted it m8 although never heard of a valve seat coming out but suppose its possible!
Old Jun 14, 2006 | 10:36 AM
Lo@der's Avatar
Lo@der
Not the most common thing is it?
Old Jun 14, 2006 | 03:04 PM
silky16v's Avatar
silky16v
Get on That!
can happen the head has had the arse skimmed off it and it's been skimmed into the valve seat area thus making the valve seat weak
measure ya head before u refit it if it's below 138.68mm you would be well advised to replace it
Nov 1, 2015 06:53 PM
