Fitting a RS 500 intercooler to an Esc Cos?
Old Aug 10, 2004 | 03:09 PM
Turbo lag's Avatar
Turbo lag
Default Fitting a RS 500 intercooler to an Esc Cos?
Hi while my engine is out I thought about upgrading my chargecooler to a RS 500 spec intercooler.
What is involved?
cheeRS Dave.
Old Aug 10, 2004 | 04:14 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Getting one that is designed for the Escort and not a Sierra / Sapphire / drilling the cross member to accept the intercooler and providing you are using the standard size hoses, that's about it.
Old Aug 10, 2004 | 05:18 PM
Turbo lag's Avatar
Turbo lag
hi mike does it fit in front of or behind the radiator and will there still be space for my swirl pot and will I have to change any hoses?
Dave.
Old Aug 10, 2004 | 05:30 PM
Disabled Account's Avatar
Disabled Account
Dave.
Dave,
It deffo fits in front of the water radiator. There will be enough space for the swirl pot, and you can use the standard I/C outlet to throtle hose BUT IMO * the turbo to I/C hose needs to be a special one........main problem is the proximity of the alternator, it will tend to rub on a standard hose and as the engine moves quite a lot, it wont be long before is wears a hole in the hose. I will post some pics up soon.
* Are you using a T4 turbo???? If not than you will need a special hose anyway.
Old Aug 10, 2004 | 05:39 PM
Disabled Account
Special stainless angled elbow was made up, then the standard (or Samco/Roose hose) RS500 hose is cut and attached to the elbow, thia allows plenty of adjustment to give clearance away from the alternator:
Old Aug 10, 2004 | 05:49 PM
kjc300's Avatar
kjc300
Genuine 500 i/c, you have to cut off the turbo side spout and rotate it outwards 180 degrees and weld the bugger back on!! Then you get a pair of hoses from roosemotorsport i.e. 3" to standard esc cossie size turbo/throttle body!! As for mounting it, there are some holes just in front of the radiator mounting points which work a treat!!!
Old Aug 10, 2004 | 06:06 PM
Turbo lag's Avatar
Turbo lag
thanks lads I don't think I will be fitting a genuine RS500 one ( hard to get hold of ) I was thinking of getting the next best one from the Performance Ford trial what they did, but I can't find a copy of the magazine anywere
Dave.
Old Aug 10, 2004 | 06:10 PM
kjc300's Avatar
kjc300
You're right, I only found one today!!!! It's the Lord Lucan of car magazines!!!
I really should subscribe!!!
Old Aug 10, 2004 | 11:15 PM
COS 22's Avatar
COS 22
i got a radtec one and its easy to fit, contact me if you want one as i have a deal set up with them for rs members
Old Aug 11, 2004 | 07:58 AM
Mike Rainbird
Caraholic
Definitely go for the Radtec Racing one (specifying Escort Cosworth fitment), where the angle of the dangle (turbo to intercooler pipe) is modified to suit the Escort .
Old Aug 11, 2004 | 08:23 AM
St3V3_C's Avatar
St3V3_C
I have used the holes already drilled just in front of the rad mounts, but had to bend these back a bit.
Old Aug 11, 2004 | 11:59 AM
Turbo lag's Avatar
Turbo lag
what happens to the little water pipe that goes into the chargecooler do you just blank it of ?
Dave.
Old Aug 11, 2004 | 12:04 PM
Mike Rainbird
Caraholic
You have two choices - fit a u-bend to feed it back to the thermostat or change the metal pipe that runs along the side of the engine to a Sapphire item (which doesn't have the "swan neck") and heat the connection in the thermostat and rotate it 180° so that it is facing the correct way. Obviously the former is the easiest.
Old Aug 11, 2004 | 12:49 PM
Turbo lag's Avatar
Turbo lag
anyone got any pictures of mikes modification?
Dave.
Old Aug 11, 2004 | 12:51 PM
Disabled Account
Dave.
I have a pic of the "U" bend pipe..........will upload it soon......take a few mins.....
Old Aug 11, 2004 | 01:13 PM
Disabled Account
Old Aug 13, 2004 | 09:18 AM
extra11's Avatar
extra11
Come and see us at National day next Sunday (22nd) We will offer great deals to all RS and PF members
Old Aug 13, 2004 | 09:59 AM
St3V3_C's Avatar
St3V3_C
Doug Stirling, Where did you get that bit of pipe? How much?
Old Aug 13, 2004 | 10:07 AM
Disabled Account
Steve, I fitted all new water hoses to my car (standard Ford)...well one of the "old" hoses, cant remember witch one, allready has a bend in it at one end 90° (ish), so I cut that bit off, bent it round a bit more making sure it was'nt going to kink - and thats what I fitted.
Cheapskate of the year award to me
Old Aug 13, 2004 | 10:08 AM
St3V3_C's Avatar
St3V3_C
Mate, have you seen mine?
I will have to take a look around for a bit of pipe I guess...
Carlbacciochi
24
Jun 30, 2016 04:31 PM
Michael Wisbey
Aug 14, 2015 11:57 PM
RsS2daz
Aug 14, 2015 05:26 AM
cameron2
Aug 10, 2015 12:14 PM
